07-30-2019, 06:46 PM | #1 |
Reviving funky seatbelts... suggestions?
As I near completion of my interior, I'm down to doing something with the seatbelts. I've had great success with recoloring everything using SEM but, I don't know how to approach the seatbelts themselves. They are tan or saddle with the usual grunge embedded in them. Is it feasable to try to restore them or just bite the bullet and buy new (LMC)? Can the fabric be dyed and made soft and flexible again? Dying them black is perfectly fine with me.
07-30-2019, 10:09 PM | #2 |
Moderator
Re: Reviving funky seatbelts... suggestions?
You may be able to clean them. The guy in the video does them in the vehicle. I pull them out to clean em.
If they're too nasty, moldy, or frayed you can get them re-webbed.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
07-30-2019, 10:45 PM | #3 |
I’ve had success using hand cleaner with pumice in it for seat belt cleaning.
07-30-2019, 11:08 PM | #4 |
I’ve had pretty good luck cleaning seatbelts. I take them out of truck and pull the belt out of the retractor. You’ll have to clamp the belt, to keep it from retracting back in. I don’t place the retractor in the water, but place the belt in hot water with some type of cleaner. Just use your favorite. I’ve used Simple Green or Dawn. Let them soak for awhile in the soapy hot water. You can mildly scrub the belt, but not too hard, or you’ll make the belts rough. Rinse and hang to dry. On stubborn belts, I used my steam extractor next.
Now if you by new belts, don’t get them from LMC. They don’t come with a retractor casing. So they are pretty ugly. I got mine from the seatbeltstore.com https://www.seatbeltstore.com/product-p/ju7387ct.htm Now I only got new belts, because I did a color change on my interior, and I couldn’t find original Charcoal belts. Took about 4 yrs of searching, but I finally have a set. Here’s a pic of the belts I got from the seatbeltstore.com
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
07-30-2019, 11:28 PM | #5 |
Thanks for the info.
My bigger question concerns re-coloring them from tan to black. How do you it properly? If my wife rode in the truck and climbed out with a black streak across her shirt, that would be the end of me. I assume you don't use the SEM aerosol I used on the plastic and vinyl? |
07-30-2019, 11:32 PM | #6 | |
Moderator
Dawn or the purple stuff from WalMart and darn hot water.
08-05-2019, 08:13 AM | #7 | |
TKCR
Did you try them to see if they fit the buckle (female) of the GM? How close is the stitching to stock belt webbing .
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
08-05-2019, 10:45 AM | #8 |
No I didn’t try to see if they snapped to the female side, because the new seatbelts came with new buckles. They have the GM logo on them. They webbing and the stitching is the same. The only thing that looks different, is the retractor casing. This is the part, that LMC doesn’t have, it is all exposed.
08-05-2019, 10:55 AM | #9 |
Moderator
The stitching may actually be a Federal DOT or NHTSA regulated thing.
Not positive but I'd be willing to bet $1 that it is regulated.
08-05-2019, 11:03 AM | #10 |
They are. And the retractors, have the ELR & maybe even the ALR built in. So they meet all the Safety Regulations.
08-05-2019, 11:23 AM | #11 |
You can re belt the factory retractor casing with the new belt. if your retractor casing cover are in good to ok shape.
08-05-2019, 11:27 AM | #12 |
That is true. It’s expensive though. I had no choice, I was doing a color change in my truck, Burgundy to Charcoal. It took 4 yrs, but I finally found a nice set of OEM Charcoal belts. Just need to swap them in, in place of the aftermarket ones.
08-05-2019, 01:07 PM | #13 |
Moderator
I never looked at the pricing. Is it more $ than buying new pieces?
08-05-2019, 02:08 PM | #14 |
I've seen the guy on the youtube channel AMMONYC do some pretty good work on belts with hydrogen peroxide.
It might be worth a shot. |
08-05-2019, 03:15 PM | #15 |
Get them swapped and give me a deal on your aftermarket ones. Win-win?-
08-05-2019, 03:20 PM | #16 |
That SnakeOyls place quoted $1000, they look new when you get them back.
08-05-2019, 03:21 PM | #17 |
When I do, I will be selling them. It might not be until winter downtime, before I do them.
08-06-2019, 06:03 AM | #18 |
Re-webbing my original retractors costs me around 450 plus plastic dye for the repaint of the housings. This also included the shop wrapping the buckle side belts with vinyl to try and give them some stiffness since the original plastic was shattered. I often wonder if replacement set would have been better.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
08-08-2019, 09:23 PM | #19 |
I took care of SnakeOyls lawn in Dallas. He ran the business out of his house. The garage door was always open with UPS coming and going. I heard his daughter was running it now out in Tyler. It was mostly Corvettes back then. I did Amos Minters lawn as well. He ran it out of his house as well. It was a car guys heaven.
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
08-09-2019, 06:04 PM | #20 |
Just received my seat belts today from seatbeltstore.com. Couldn't be happier with their product, love the GM buckles. The covers on the retractors are black on mine because of color choice ( copper ) on some colors they are color matched to the belt. I may just leave mine black so it will have some contrast. If you buy from them you wont be disappointed.
84 step side 87 swb |
08-10-2019, 12:21 AM | #21 | |
08-15-2019, 12:39 PM | #22 | |
08-15-2019, 03:59 PM | #23 |
I would use RIT fabric dye. I dyed my carpet with it and it came out great. Just be sure to follow directions and rinse thoroughly.
1986 gmc 1500 4x4 350/700r4 |
08-15-2019, 04:46 PM | #24 | |
08-17-2019, 01:36 PM | #25 |
I figure this is related, so rather than start a new thread I'll ask the question here:
Anybody know where I can buy these plastic retractor covers? For a '75 Cheyenne. Untitled by awesome_adawson, on Flickr Mine are chalky and crumbling... I reckon they're beyond restoring, if I pull them off I bet they'll turn into dust! The only ones I have seen are for the 3 point belts...
"Sweet Pea" 1975 Cheyenne 20 http://67-72chevytrucks.com/vboard/s...00#post8477900 "Bourbon" 1975 Suburban ScottsdaleSOLD https://67-72chevytrucks.com/vboard/...49#post8769049 ”Otis” 1970 C10 SWB -SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=762766 ”Chebby” 1962 Impala LS/TKO-500 http://www.pro-touring.com/threads/1...2-Impala-Build |
