Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 07-31-2019, 03:38 PM   #1
Nobighurry
2sp rear question
Question - can you shift the rear from H to L without downshifting the trans? The reason. I ask is when hauling I often need to move from H to L but stay in 4th gear - like when climbing hills loaded. Dropping to 3 H would be too low gear. I dont want to tear up the splitter.
Nobighurry is offline   Reply With Quote
Old 07-31-2019, 07:35 PM   #2
C10 - C90 Bill
C10 - C90 Bill's Avatar
Re: 2sp rear question
Sure can. Just push down on the button, dump the clutch in and out quick, give it some gas and it will shift just fine.
It will actually shift better if you keep your foot on the gas the whole time. Don't hesitate.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 07-31-2019, 07:55 PM   #3
Nobighurry
Awesome. That's what I was hoping for. Just didn't want to tear it up. Thabk you
Old 07-31-2019, 08:21 PM   #4
Pvmt-Pndr
Keep in mind that you need to raise the rpms to get the rear gears to synchronize. I don't have much practice with this yet but the two times I've tried were an epic fail. The rear end was screaming at me until I gave up and popped it back to high. I only did it for my own amusement last time I ran the truck down the road.
I actually found a couple of old YouTube videos that explain how to do exactly what you're asking quite well too. Type in something like how to shift a 2 speed rear end. It's clearly quite an old video and it was 2 parts. They stress not shifting the rear end going down hill ever due to a higher chance of a run away situation.
Pvmt-Pndr is offline   Reply With Quote
Old 08-01-2019, 02:05 AM   #5
Airdirect
When up shifting, raise the 2 speed button, then let up on the accelerator, once you feel the shift take place press the accelerator down. Works real smooth.
When down shifting, lower the 2 speed button, then ease up on the accelerator followed with a quick press of the accelerator down. The easing up allows the gears to go into neutral then you accelerate the drive shaft to allow the gears to re synchronize into the lower gear.
Works very smooth when done properly. Next time I am out in my truck I will try to take a video and demonstrate.
Airdirect is offline   Reply With Quote
Old 08-01-2019, 06:35 AM   #6
Nobighurry
Thank you. That would be great.
Old 08-01-2019, 08:21 AM   #7
C10 - C90 Bill
Many like to use no clutch, but it will shift smoother and safer with the clutch. As even recommended by the manufacturer.
GMC 9500 Fan
Detroit Diesel Fan
Old 08-01-2019, 08:29 AM   #8
Airdirect
Shifting up can be done with the clutch as the drive shaft will slow down when the clutch is disengaged allowing the gears to synchronize. However down shifting will not work with the clutch disengaged as you have no way of accelerating the drive shaft to allow the rear end to synchronize.
David
Old 08-01-2019, 08:42 AM   #9
C10 - C90 Bill
You just use the clutch like you are shifting a trans gear.
Even though I like all my gears in the trans, I drove 2-Speed Rear trucks for over 18 years.
GMC 9500 Fan
Detroit Diesel Fan
Old 08-01-2019, 01:32 PM   #10
Pvmt-Pndr
Good videos
"Eaton 2 Speed Axle Part 01" on YouTube
https://youtu.be/SVDSYSBvjgY
"Eaton 2 Speed Axle Part 02" on YouTube
https://youtu.be/osDi3hpovnc
