Old 08-04-2019, 07:52 PM   #1
Jake Wade
Jake Wade's Avatar
Body Lean
2006 Silverado crew cab 5.3, 2wd. 9/16" lower on drivers side front. 3/8" lower on drivers side rear. Yesterday I installed a new Moog coil spring (60148) and a new upper coil spring rubber isolator, just on the drivers side. No change. WTH? where do I go from here?
Jake Wade is offline   Reply With Quote
Old 08-05-2019, 07:34 AM   #2
Re: Body Lean
Typical Chevy lean. Most all GM model trucks seem to have it after a while. What I did with my old 2002 is I carried my tools, mini floor jack, etc on the passenger side of the truck bed. The extra weight helped balance it out. I guess having the fuel tank on the drivers sides tends to cause that side to sag sooner.
ADDED: I do believe they had a service up date that added an extra spring spacer to help with the front. I have seen folks swap the rear leafs from side to side also to help balance it. My way was the cheapo, I have no money fix.
Old 08-05-2019, 07:52 PM   #3
Jake Wade
Jake Wade's Avatar
Re: Body Lean
Thanks! I may try swapping rear leaf springs
