08-11-2019, 12:26 AM | #1 |
You might be a hot rodder if:
You might be a hot rodder if this is how you spend your Saturday night.
08-11-2019, 12:30 AM | #2 |
Re: You might be a hot rodder if:
I agree.
What is this going to be install on? Great looking work. .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
08-11-2019, 03:17 PM | #3 |
53 1/2 ton. 292 with 4-71 blower, billet crank and cam, 12 port cross flow aluminum head 3 Roch 2 bbl. Backed up with TKO 600 5 speed, Frankland quick change rear end with Bicknel torque arm. 12.88" Wilwood disk brakes.
08-11-2019, 05:20 PM | #4 |
Cool it was a bit hard to visualize what it was going to be at first.
08-11-2019, 05:46 PM | #5 |
I still can't recognize it; blower belt drive guard?
Edit: Okay, I found it. Respect man...
1951 Chevy Panel Truck |
08-11-2019, 10:30 PM | #6 |
Yes blower belt cover. The center section was a heavy brushed finish and the cutouts had a lot of chatter in them so I first started with 220 grit on the flats and in the cutouts. The other pieces are machined so I will start with 400 or 600 on those. The cutouts are a real PITA. I've got about 7 hours in it at this point. Sorry about the picture of my brand new Basset hounds I couldn't resist.
08-11-2019, 10:51 PM | #7 |
gorgeous man! you dont need to worry about needing a custom milled belt cover to be thought of as a hot rodder by the way, the rest of your truck already speaks volumes.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
08-11-2019, 10:51 PM | #8 |
I don't think I have many hours that my Puppy is not right there in my business .
Those are some cute Puppies. Just a suggestion. If you break the corners on all those cutouts with a file set like this one in the link below it will save you a lot of time. https://www.harborfreight.com/needle...-pc-69876.html .
08-11-2019, 11:03 PM | #9 |
I'm just trying to get it flat right now. I'm working 500 miles from home right now and have limited stuff with me. Just brought a few things with me to work on. Thanks Those files are handy.
08-12-2019, 11:53 PM | #10 |
yep, been there many times.
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
