Old 08-19-2019, 11:18 PM   #1
Ziegelsteinfaust
Boyd Coddington Corvette rims
Today I was digging through a storage place I have looking for stuff I could use on my Willy's, and Camaro projects.
I ran across my Boyd Coddington rims I got with a wrecked 92 Corvette I bought for the motor.
The fronts are 17x9 with 275/45/r17 tires, and the rears are 17x10 with 315/35/r17's.
So besides the obvious Corvette offset. Can you make these for a C10 with out cutting the fenders aka early NASCAR style? Or are the rims to small to fit over the A-arm?
I want to build another muscle truck, and a actually keep it this time.
Ziegelsteinfaust is offline   Reply With Quote
Old 08-20-2019, 10:38 AM   #2
Willie Makeit
Willie Makeit's Avatar
Re: Boyd Coddington Corvette rims
not the same bolt pattern so you'll have to overcome that issue first
Willie Makeit is offline   Reply With Quote
Old 08-20-2019, 09:15 PM   #3
katykitchen
I remember when those came out someone made adapters so that you could use them on other stuff.
katykitchen is offline   Reply With Quote
Old 08-20-2019, 10:11 PM   #4
Ziegelsteinfaust
These rims are steel hoops with billet centers, and all triple chrome plated. If I got a gmt-400, and dropped these babies on. It would be a cover truck from 88-92. To give you a idea of how dated they are.
I will have to use something like 2-2.5 inch adapters to even begin to make them work.
After I saw them. I began to wonder if anyone has put this wide a rim under a truck with out fender mods.
Old 08-21-2019, 05:27 AM   #5
LT7A
What do they look like?
Old 08-21-2019, 12:01 PM   #6
Ziegelsteinfaust
I will post a pic later today or tomorrow when I go back since a friend wants a radiator I have.
Old 08-21-2019, 07:03 PM   #7
SCOTI
SCOTI's Avatar
I'm betting no. But, "would" they fit is kind of based on the ride height & what dimensions you can do for the adapters needed to make it possible. They definitely make a billet GM car to truck pattern adapter. Minimum thickness is typically 1" & I've seen them 3" thick so it's just a matter of doing some measuring & calculating.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-21-2019, 08:26 PM   #8
Ziegelsteinfaust
The rims. The lips got a bent in a spin out accident which is why I got the whole Vette for the engine. I plan to have the straightened, and powder coated for some project.
1992 Boyd rims https://imgur.com/a/cdcazaI
Old 08-21-2019, 08:32 PM   #9
Ziegelsteinfaust
Old 08-22-2019, 12:37 PM   #10
nlped
nlped's Avatar
Those are all aluminum wheels. Billet aluminum center with cast outer. I use to sell A LOT of those back in the Super Shop days. You’ll certainly be able to fit them with the proper adapters, Tire size etc. if you don’t have the centers, you probably won’t ever find more.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 08-22-2019, 07:05 PM   #11
Ziegelsteinfaust
I have the centers too. So I am very tempted to build something just to use them. It just has to be right.
They have steel hoops. On the back pair the chrome is cracked to the steel, and my magnet sticks to them nicely. When I pulled the tires off for my Camaro project I was shocked to find steel hoops. As all my limited experience with Boyd's is they were all aluminum. Either the whole rim 1 billet piece, or aluminum center with aluminum hoop.
