Old 08-22-2019, 08:52 PM   #1
joeld
Fuel tank replacement 1963
I need to replace the gas tank on my 1963 chevy shortbed. It's started leaking at the bottom area due to several small rust holes. After lots of reading thru old posts it seems LMC is the preferred vendor for this? Just want a simple replacement type. I will order the sending unit gasket and the rubber fill pipe also. Any tips appreciated.
Joel
joeld is offline   Reply With Quote
Old 08-22-2019, 11:11 PM   #2
Softpatch
Softpatch's Avatar
Re: Fuel tank replacement 1963
When you find the "Gasket"
Tube to body opening (under gas cap)
buy two
they are cheep and don't hold up...
The short hose (on the filler kneck)
is a bit trickey to get set right and able to get to the clamps.
Every one I have done I've had to "Fine tune the Float'
just be prepared to Open the tank More that once for adjustment
and Don't worry about hi side it's the low mark EMPTY is what you should be working towards.
Most these trucks have "Dancing" gas gauge
Because of sloshing in tank
....... and be mindful of the grounds you can never have to many Grounds on an old truck
Did you know the Bed gas tank is almost the same price as the "In cab tank"
$140-$175
.....Sp
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 08-23-2019, 10:09 AM   #3
joeld
Thanks for the reply. Yea, I did notice the price of the bed tanks. I assume the tanks that LMC sell are good quality?
Joel
Old 08-23-2019, 11:04 PM   #4
slepysal
slepysal's Avatar
If your on a budget you can try to find one on craigslist offer up or letgo.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 08-23-2019, 11:44 PM   #5
joeld
I ordered tank, grommet, neck, sending unit gasket and filler hose a few minutes ago from LMC. I'll post back next week when I get it all in. Thanks for the replies.
Joel
Old 08-24-2019, 06:28 AM   #6
richards72chevy
richards72chevy's Avatar
I think lmc is kind of like harbour freight.Some things are great others are terrible.The few things I have got from lmc are fine.I'm going with a rear mount gas tank on my 66.I will more than likely get it from brothers or early classic enterprise.
richards72chevy is offline   Reply With Quote
Old 08-24-2019, 10:27 AM   #7
ImpalaJim
ImpalaJim's Avatar
I got the rear tank for 64 66 (LMC) mines a long bed does not work ugh!!! They don't say any thing about it being for short bed only
ImpalaJim is offline   Reply With Quote
Old 08-24-2019, 11:09 AM   #8
oem4me
Factory in-cab tanks are frequently for sale given the popularity of rear tank conversions. My first choice for quality is always going to be a factory part over aftermarket, and in this case they are cheaper too!
Old 08-24-2019, 01:23 PM   #9
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
How much did everything come to?
66 C20 Service Truck:
Old 08-24-2019, 05:34 PM   #10
joeld
Originally Posted by lostmy65 View Post
how much did everything come to?
$262.99
Old 08-25-2019, 12:36 AM   #11
allchevy58
allchevy58's Avatar
Bought mine at Summit Racing, fit just fine.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 08-25-2019, 08:13 AM   #12
Cohi
Cohi's Avatar
I have a 66 LB, LMC's rear tank fit fine. I should have got a side fill, but oh well.
Denver/Big Island -- Instagram: Slammed66c10
'46 Fleetmaster Coupe
'64 C10 on Ridetech Air Ride
'66 C10 on GSI Bagged Chassis - in progress
'12 FLHR
'11 Custom Homebuilt Chop/Softail
Cohi is online now   Reply With Quote
Old 08-25-2019, 10:43 PM   #13
Softpatch
Softpatch's Avatar
Bought a LMC (in cab ) tank
few years back for my 63 LB
good price It fit and worked No complants
Sp
Old 08-29-2019, 09:59 PM   #14
joeld
OK. All parts arrived Wednesday around 2:00 PM. For the money I was satisfied with the quality, and everything did come in the same box. Installed the tank today without any major issues. Just a little aggravating doing it by myself. Got a few gallons of gas poured in and no leaks, will add more Friday but should be ok.
Joel
Old 08-30-2019, 12:54 AM   #15
slepysal
slepysal's Avatar
Joel
Great to hear! I feel you on working alone !!
