Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 08-24-2019, 09:06 PM   #1
Pvmt-Pndr
Engine Removal
I am wondering if there is physically enough room to pull the engine out if I only remove the radiator and hood of my truck. I have a cherry picker that has some personal touches on and will lift 1k pounds 10' in the air. It looks like it would be an extremely tight fit. Is removing the grill a must do on these trucks to get the engine out and if so is there anything I need to look out for? I managed to get the trans back out again today and will be getting the engine ready to pull within a week or so I hope.
Pvmt-Pndr is offline   Reply With Quote
Old 08-24-2019, 10:24 PM   #2
Airdirect
Re: Engine Removal
The radiator support is also the grill. Easy to remove and you will have plenty of access. Not sure you will even need to remove the hood. That vintage could be different than my 1979, but I believe they are built very similar.
Airdirect is offline   Reply With Quote
Old 08-25-2019, 12:28 PM   #3
Pvmt-Pndr
Re: Engine Removal
It looks like you're right. When I was looking at it yesterday it seemed the seams were a bit too tight to easily come apart. I figured out why... they're all caulked. I'll be working on this over time and hope to have it out in the next couple of weeks. Thanks Airdirect
Old 08-26-2019, 06:31 PM   #4
txagincali
Re: Engine Removal
I pulled the whole front clip for my swap, but if you pulled the Radiator and Grille, you should have no problems.
Just be sure you can get to all of the trans bellhousing bolts first (tight and covered in decades of road grime). I tried to pull the engine and trans together but the tunnel wouldn't clear the hump in the trans and had to undo the front body mount bolts and jack the body up ~2" for it to drop out as one unit. Probably a lot easier if split, but I also couldn't get to a few bolts when I partially tried.
1963 Olson Grumman Bread Van - Possible Suburban Swap (sporadically worked on to strip paint)
1969 GMC C10 Pickup SWB Stepside (heart transplant)
1969 Chevy C50 Fire Truck converted to Utility Truck being built into Pickup Truck (newest addition, accumulating spare parts)
1972 GMC K5 Blazer 4x4 (sporadically being worked on, accumulating parts)
txagincali is offline   Reply With Quote
Old 08-26-2019, 11:09 PM   #5
sweetk30
sweetk30's Avatar
Re: Engine Removal
not your body style but my 73-87 body style gmc7000 i pulled the core support and all was good .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 08-27-2019, 03:17 AM   #6
Pvmt-Pndr
Re: Engine Removal
Thanks guys! I'll post pictures as a reference for anyone pulling the engine on my era truck when it's all done.
Old 08-27-2019, 09:26 AM   #7
txagincali
Re: Engine Removal
Just for reference when you are getting into it, here is my 69 with the grille/core support removed but the rest of the body panels on it. I still pulled the hood and fenders off before I pulled the motor but not because I had to, but because I needed them off eventually anyways so it just made things easier when pulling the motor/trans. Mine is a 292, so if you have a 366 or 427, you can account for having less room.
Old 08-27-2019, 09:51 AM   #8
Pvmt-Pndr
Re: Engine Removal
Perfect. Thanks! At least now I know which seams I'm splitting to get it apart.
Old 08-27-2019, 08:43 PM   #9
1948ChevyDumpFixer
Re: Engine Removal
One trick I always used on the dozens of Chevy engine swaps I've done....remove the motor mounts first, and install them last. You can easily remove them or install them while hanging on the cherry picker, and it makes manuvering the engine around between the crossmember so much easier.
1948ChevyDumpFixer is offline   Reply With Quote
Old 08-27-2019, 11:41 PM   #10
Airdirect
Re: Engine Removal
I concur, they will slide in very easy without the motor mounts in the way. Once connected to bell housing, you can slip the motor mounts in.
