Old 08-27-2019, 07:12 PM   #1
St Cloud Rustoms
Big block motor mount confusion
63 GMC 1000
Well, I thought I was getting the right 73-87 clamshell mounts, but maybe I got the wrong ones. I've seen some posts about having to add a 1" spacer under the frame side on some, but I thought I was getting the right ones that don't need the spacer. Can anyone tell where I went wrong?
I also have a set of small block mounts, but putting them up to the frame make it look like I would need a 1" spacer as well? I'm kinda confused.
St Cloud Rustoms is offline   Reply With Quote
Old 08-27-2019, 11:30 PM   #2
Captainfab
60-66 Nut
Re: Big block motor mount confusion
Did you get your '73-'87 brackets from a C10 or a C20/30? If from a C10, that is part of the problem. Those are longer than the C20/30 brackets. You may still need a little spacer if you move the engine forward much.
Old 08-28-2019, 10:30 AM   #3
St Cloud Rustoms
I guess that's where i might have gone wrong. They weren't out of a c20/c30.
Even matching up the small block mounts that were out of a 67-72 c10 don't look like they'd work. Matching up mount placement and angle, it looks like I would be in the same scenario.
Another issue that I'm seeing is that as it sits now, if i used the 73-87 mounts with a 1" spacer on the frame side, my oil pan would hit the ground before my frame / crossmember.
I think I'm going to need some after market mounts that lift the motor a bit. Any options or input?
Old 08-30-2019, 05:42 AM   #4
shortstep60
I used 1970 bbc motor mounts on my 65 and it fits nice. I do have some bbc mounts on a c20 1978
shortstep60 is offline   Reply With Quote
Old 08-31-2019, 09:25 AM   #5
St Cloud Rustoms
Any chance you could post some pictures so I could see fitment?
Old 08-31-2019, 11:32 PM   #6
Captainfab
60-66 Nut
There are several pics in this thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=551120
