Old 09-05-2019, 10:38 PM   #1
Bandit130
Bandit130's Avatar
AC/Heater blower motor does not work on high.
Searched and did not find this issue. The blower motor shuts off when switched to high. Works on all other speeds. Not sure if it switch, relay, or the motor. Suddenly stopped yesterday while using AC. Changed to Bi-level to use the fan speeds, except high.
I did run a jumper from B+ to blower motor, and motor did run on high. Removed connectors from relay and resistor and reset both and no change. I will remove connectors and clean contacts tomorrow and I am planning to have the resistor tested by a co-worker that is an electronics engineer to see if it is still good. May need a new resistor or relay, not sure yet.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 09-06-2019, 03:45 PM   #2
MikeB
MikeB's Avatar
Re: AC/Heater blower motor does not work on high.
The resistors are used to drop voltage for low and medium speeds. They are bypassed when the dash switch is set to HI speed. The problem is probably the dash switch itself or the connection to it. Neither would be an uncommon problem.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 09-06-2019, 06:50 PM   #3
Bandit130
Bandit130's Avatar
Today removed relay, cleaned connector prongs, took apart and cleaned contacts. No difference. I was tapping on relay and fan came on high for maybe a minute then stopped. Decided to replace relay and still same problem. Also removed resistor, inspected and cleaned contacts and same problem.
Tomorrow, plan to remove climate control unit just enough to inspect unit and switch. I have inspected and lubricated temp lever when I bought truck cause lever was super hard to move. All things have been working well lately until this.
Mopar by Birth
Chevy by Choice
Old 09-07-2019, 04:02 PM   #4
Bandit130
Bandit130's Avatar
Figured out the problem. There is an orange 10 ga wire on motor relay that goes thru harness to firewall that has an inline fuse connected to the junction block. The fuse holder was burnt. Replaced fuse holder, now have the high speed on blower. This wire has a constant 12v.
Mopar by Birth
Chevy by Choice
Old 09-08-2019, 07:39 AM   #5
Glad you found the issue. Never have seen a fuse holder on one.
