09-08-2019, 12:59 PM | #1 |
Dual tanks: any way to manually force alternate tank
I have the dual tank setup, the truck seems to default to the right hand (passenger side) tank. I have replaced the dash switch and the fuel line switch on the frame and I cannot get this to work predictably, and I need to switch to and use the left hand (driver side) tank. Anyway to do this?
09-08-2019, 07:10 PM | #2 |
Re: Dual tanks: any way to manually force alternate tank
i modified my setup to pass side is a jerry can basicly . i used the tbi sender and pump that was in it to pump over to the driver side and dump in the filler neck vent hose tee i installed . i have it set up on a switch and a BIG red light under the radio so i do not forget its on . also its only feed power key on . so if the key is off it will not pump .
my driver side tank has i much higher psi pump and lines for it to feed my aftermarket edelbrock pro flo 4 efi setup . in hind sight tho i wish i had set it up for right side main tank as most vehicles now are coming right side filler and pulling in to the pumps is a bit of fun when there full as everyone is driving for right side fill . and my efi lines could have been 3 feet shorter also .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
09-08-2019, 08:58 PM | #3 |
Moderator
What year is your truck?
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
09-08-2019, 09:36 PM | #4 |
If it is an emergency type situation, just swap the left/right hoses on the tank valve. NOTE: If you do this, the gauge will now show the NOT IN USE tank as the gauge is switched by the switch and not the valve.
If you have one of the older style solenoid valves, they default to a non powered side, normally the passenger side. IIRC - the motor driven ones stay on the tank last selected when power is lost. Alternative method. Just feed the hose(s) from the drivers side tank direct to the frame pipe, bypassing the valve. |
09-08-2019, 10:21 PM | #5 |
Sweetk30, do you have a fuel gauge on your "jerry-can" at all? Seems like an odd way of plumbing things, but it is simple and it does work....
A note on the fuel tank sides. A reason to have the dominant tank(the one most often full) on the right side, is that it can counterbalance the driver. The fuel tank and the driver are the primary off-center loads in a vehicle, so you might as well have them on opposite sides. Of course, it doesn't matter much on a one ton.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
09-08-2019, 11:29 PM | #6 |
Moderator
If you have a 73-80 truck it's easy enough to change the AUX tank from the LH to the RH side.
Swap the supply and return hoses from the LH & RH senders on the valve. Unplug the Packard plug from the switch. -One side of the plug has a blocked off angled terminal hole and a RED and Green wire. This side powers the valve with the switch in the AUX position. -The sender side of the plug has two angled terminals and one straight terminal. This is the sender switch. The output to the gauge is on the centre terminal and the wires from the senders are in the corners. Swap the corner wires to make the gauge read the proper tank after you swap the hoses around. This is the dual tank theory of operation thread. It should answer a lot of questions. http://67-72chevytrucks.com/vboard/s...d.php?t=754061
09-09-2019, 11:23 AM | #7 |
i did install a autometer 2 1/16" z-series gauge for the jerry can tank yes .
09-09-2019, 01:33 PM | #8 |
09-09-2019, 01:36 PM | #9 | |
09-10-2019, 10:34 PM | #10 |
Moderator
OK.
You should have a 1981-1991 NL2 dual tank setup. This is the motorized valve that'll stay on the tank you select til you switch it. Leave it set for the RH tank and use that tank. No need to play games with the hoses or the switch.
