![]() Join Date: Feb 2005
What size Nut?
What is the size nut that goes on the end of e-brake front cable ( see picture ). the other end goes top the e brake pedal inside the cab. also is metric or standard?
Big Blue ( John ) 79 Chevy Pick up.....My Dailey STILL Working on a frame up: 1987 Truck body on a 78 Blazer frame. Need cab blasted to start project. Got the cab BLASTED, Now Prep and Paint. Started to lay SOME BONDO and primer. Done, Ordering paint. Got paint, Stuff painted,Cab,Fenders, Hood more later. 9/7/2015 Got the clear coat on,now time to take one off. Started to put things back (What a nightmare) like the heating and AC stuff,inside wire harness, outside AC unit and booster, still more. May 2016, still working on the inside. Got duck work in,heating and AC. Radio (stock) in dash with after market in console later, Speaker are hooked up, Steering column is in. Getting ready to drop the cab onto the frame, Working on engine now since I have the room. Well here it is 2018, got the engine in and it runs, now I need to get the exhaust system in so I can adjust the lifters, to loud right now. Got the exhaust on now I am waiting for the break parts to come in. |
#2 | |
![]() Join Date: Jul 2000
Re: What size Nut?
I suggest you get a few of the most common bolts, nuts, and washers for your garage, such as 5/16-18 and 3/8-16 threads, also known as 5/16 NC and 3/8 NC (national coarse) threads. Most old truck guys have cabinet drawers full of them, along with 1/4" hardware, and a variety of washers and lock nuts. Under the hood, many of the body fasteners are 8-1.25 mm.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
Re: What size Nut?
Thanks MikeB, I made a list of nuts and bolts lock washers for supply. Thanks Again John
