09-12-2019, 03:18 PM | #1 |
Spun a cab mounting nut
Im looking for ideas on how to fix this. I the cab mounting caged nut break loose when removing the bolt. I was able to get the bolt out by using a hole saw to cut a hole above the nut so I could hold it still.
Now I need to fix it - figure my options are: - 1) remove the caged nut and replace with a 1/2" nut welded to a piece of 1/4" steel plate. - 2) leave the nut in place, wedge some steel plate between the crossmember wall and the nut to hold it in place. Anyone done this before? |
09-12-2019, 03:49 PM | #2 |
Robert Olson Transport
Re: Spun a cab mounting nut
Ive used a lock washer regular washer and a nut with great success I also used a couple of zips to screw a cover over the hole saw hole in case I need to get into it again and it keeps dirt out
09-12-2019, 04:47 PM | #3 |
I would also consider a flanged nut as they give you more surface area to weld too.
Be sure to chase the threads afterwards as the can get galled up from welding. |
09-12-2019, 07:45 PM | #4 |
if you have the hole now to get to the nut bend the tabs back tight and weld them together . the reason the nut spun was rust . clean the nuts threads with a tap and blow out . your good to go from there .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
09-13-2019, 09:51 AM | #5 |
Regarding the factory nut - are they lock nuts or normal nut. I would think a lock nut would be better since the bolts thread in from the bottom. If they are lock nuts then the tap would probably take out the "locking" feature.
09-13-2019, 12:22 PM | #6 |
i have pulled bolts from a super clean low mile 77 k30 and they had blue lock-tight on them .
