6 rib p/s pump pulley
I am looking for a single 6 rib serpentine belt pulley with a 5/8" shaft with a keyway slot. I bought ones years ago and am now finally installing my motor and I managed to damage the pulley beyond repair. I do not want to have to purchase a whole a kit again nor so I want to spend the money on a March pulley. I am not having any luck. Any leads any where?
Thanks |
Re: 6 rib p/s pump pulley
I guess I am the only person out there that is using this type of pulley system, I will find my own solution without the help of this board.
well, I suppose, if someone had a answer to your problem they would have posted up. My only answer was to buy a March pulley or check out a junk yard. But, you disted the March idea, so that is why I didn't post up
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
![]() Join Date: Aug 2018
You'll probably get a better response if you post in the 67-72 forum, not the build forum and have a little patience. Also, you can try using the search function. Not everyone gets on here every day even every few days.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
