Old 10-13-2019, 08:35 PM   #1
Afirehawk1
66 c10 Chrome Grill Source
I have read the reproductions dont fit well?
Any experiences which way to go?
I would like chrome one that actually fits correctly.
Afirehawk1 is offline   Reply With Quote
Old 10-14-2019, 06:55 AM   #2
Afirehawk1
Re: 66 c10 Chrome Grill Source
Or is painted or aluminum only available?
Fitment of these?
Old 10-14-2019, 09:39 AM   #3
AcampoDave
AcampoDave's Avatar
As for the 64-66 style grilles.....The problem with the chrome ones, which are all aftermarket, is that they eventually get rusty. Aluminum grilles were never reproduced so supply is limited to those which have survived. I have not checked to see if reproductions are available in paintable steel, but i have managed to score the originals without a lot of trouble.
AcampoDave is offline   Reply With Quote
Old 10-14-2019, 10:27 AM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Repos are available in black to paint.
Old 10-14-2019, 11:01 AM   #5
Afirehawk1
I have heard the repop chrome ones don't fit right
Any idea?
Old 10-14-2019, 12:00 PM   #6
The Rocknrod
Moderator
Never heard that. I have a chrome one I have already fit and removed. The tabs may need to be slightly adjusted in or out but it fit.
Old 10-14-2019, 03:28 PM   #7
Afirehawk1
Hhm ok
You like the chrome? Holding up well?
Old 01-13-2021, 08:47 PM   #8
vet57air
vet57air's Avatar
I am installing my 66 repo chrome grill. Problem is the two inside mounting pads are in contact with the stock grill support but the two outside bolt holes on both sides have about 1/2" of space between the grill mounting pads and the grill support. Could likely get long bolts into them and suck them in or should I use spacers?
vet57air is offline   Reply With Quote
Old 01-13-2021, 10:09 PM   #9
72cs20
A Longer bolt is what I used to bring it in and close up the gap.
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827
62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583
72cs20 is offline   Reply With Quote
Old 01-14-2021, 11:52 PM   #10
61hawk
61hawk's Avatar
Is there one source that is better quality than the others or is it everyone sells the same grill? I'm also going to be in the market fairly soon for a chrome one.
61hawk is offline   Reply With Quote
Old 01-15-2021, 11:50 AM   #11
vet57air
vet57air's Avatar
I was able to suck in the grill mounts with longer bolts. I had a bit of a time installing the headlight mounts. Had to use vise grips and clamps. I did notice on my original aluminum grill that the tabs that mount the headlights were bent over which accounts for my extra space. Overall the chrome is deceit.
Old 01-15-2021, 03:30 PM   #12
bigmoe
bigmoe's Avatar
When I assembled my chrome grill last summer that I got from Brothers it took a little jiggering to get the headlamp base assemblies attached. Some of the holes were a bit out and some of the tabs on the grill had to be bent a bit to line up at the right angle. It wasn't too difficult though.
bigmoe is offline   Reply With Quote
