11-04-2019, 11:02 AM | #1 |
Air Bag Lit
So, as of this AM, the Air Bag light stays on in my wife's 2001 Tahoe.
The manual just tells me (to paraphrase): go to the dealer and spend money. If there anyway to find out what the problem is with following the manual? am I looking at a potential random deployment or just a chance it won't deploy in a collision?
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
11-04-2019, 12:14 PM | #2 |
Re: Air Bag Lit
It will store a code. Random deployment is very rare and almost impossible. Front impact sensors and clocksprings are common. You need to get someone that can pull codes.
11-04-2019, 03:41 PM | #3 |
Re: Air Bag Lit
Many auto parts stores lend code readers to determine what is wrong, and then you can decide if you can fix it.
11-04-2019, 03:58 PM | #4 |
Re: Air Bag Lit
11-05-2019, 10:26 AM | #5 |
Re: Air Bag Lit
OK, thanks, guys.
The light has since gone out, so I will monitor it closely.
11-05-2019, 03:14 PM | #6 |
Re: Air Bag Lit
You can still get the code from memory, as long as the battery hasn't gone dead or been disconnected. If you have access to a buddy who can maybe pull SRS codes it would sweet to know what is going on. Like states front impact sensors and clock springs are common, more often I've seen the impact sensors.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
11-14-2019, 09:35 PM | #7 |
Re: Air Bag Lit
Check your fuses, also look at the rear view mirror it it not lit? then you have a fuse blown and that would make the SRS light stay on also plugs can loosen although rare I have had it happen.
