Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 11-04-2019, 11:17 PM   #1
T97
T97's Avatar
60-66 C60 C10 part interchange information.
Does anyone know if the column from a c60 will swap to a c10?
There are no c10s local that have a factory column but we have a big truck salvage yard with about 10 of these. Been looking for odds and ends with great luck but unsure if im reqdy to pull the trigger on one that im not sure will fit. Factory blinker complete steering column with decent steering wheel for 100 bucks is rare around these parts.
Any info would help i am willing to modify it as long as it looks stock in the cab.
Thanks in advance
Thomas
T97 is offline   Reply With Quote
Old 11-10-2019, 10:21 AM   #2
Bomp
Bomp's Avatar
Re: 60-66 C60 C10 part interchange information.
The C60 column is bigger and wont bolt up to the steering box of a C10.
Im trying to do a swap and am running into some of the same issues. First pic is on a '91 frame, second attempt is on a '65 C30 frame.
Good luck with your research.
Bomp is offline   Reply With Quote
Old 11-10-2019, 10:24 AM   #3
T97
T97's Avatar
Which part is bigger? Could you not modify it to work?
Old 11-10-2019, 10:55 AM   #4
ratskin
You could probably cut the shafts on both and use Borgeson joints. They make all sizes, I believe.
ratskin is offline   Reply With Quote
