11-05-2019, 07:28 AM | #1 |
Brothers LED tail lights
Is anyone here using Brothers LED tail lights in their mid 80s square body?
If so, what is your opinion of them? Thanks! |
11-05-2019, 08:25 AM | #2 |
Re: Brothers LED tail lights
I have a set been in about a year no issues with them
11-05-2019, 08:58 AM | #3 |
I have a set and get alot of compliments on them.
1984 GMC Sierra Classic 1500 1935 Ford P/U 2012 Mustang GT/CS 1985 El Camino 1974 Ford Bronco |
11-06-2019, 07:25 PM | #4 |
I bought the standard size 1157 LED bulb off of amazon direct bolt in replacement. Extra bright to keep idiot texting drivers from hitting me!
11-07-2019, 03:13 PM | #5 |
sylvania zevo series led replacement . also watching video's and personal testing always get red for red and amber for amber or clear if turn or marker . the white don't fill up the red / amber lens as good as the same color .
std 1157 bulb pic 1/3 zevo 1157 red led pic 2/4 and these are a crapy old 2 mega pix cell phone pic taker . i also did a test with 4 ways and 1 led 1 old bulb and WOW what a reaction time difference . the old would be almost out and the flasher would hit again . . . . the led was BAM on/off and faster on time .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
11-08-2019, 06:22 PM | #6 | |
11-08-2019, 06:57 PM | #7 |
I haven't done LED bulbs yet in my truck, but in preparation I put a Heavy Duty, LED rated Electronic Flasher in. the Heavy Duty version has a slower blink cycle, plus the electronic flasher VS the standard means no "Hyper-Flash"
I will say I have done the flasher conversion on other trucks with LED lights, and never had an issue with the "hyper-flash" and the relay is only $10 or $15, small change when converting all bulbs anyways. |
11-08-2019, 07:54 PM | #8 |
sorry forgot to say i run a solid state replacement flasher i got from a older parted out truck and no problems with flash speed .
its funny as my in-dash turn bulbs are still 194 bulbs and i watch them go dim/bright / dim / bright as i watch the reflection outside of the led go on / off / on / off . only thing not led is dash bulbs and plow lights . heads up if you swap front outer side fender bulbs they NEED to be non-polarity sensitive . the power leg is switched one side for marker and other for turn . i had to get my amber 194 bulbs over at superbrightled.com and select non-polarity sensitive and then my side front markers worked as normal . if anyone ventures over to ck5.com here is the master thread i did of my whole led swap with lots of pics . https://ck5.com/forums/threads/l-e-d...lights.335580/
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. Last edited by sweetk30; 11-08-2019 at 08:15 PM. |
11-09-2019, 11:08 AM | #9 |
Thanks for that.
