Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 11-05-2019, 04:37 PM   #1
DemkoG
left over blazer
I have been on the forum a long time stealing ideas and been helped out a lot by some grate forum members. I have been meaning to make a build tread for a long time. I have a little time so I thought now that I am ¾ of the way it needs to happen.
My blazer is mostly left over parts from two other blazer builds. The truck is not meant to be original in any way. And do understand that this blazer was very close to going to the scrap yard.
The build sheet
blazer frame motor cross member modified to except a LS motor
1989 ¾ ton Chevy axles 3.73 10 bolt front 14 sf posi back
2002 ls6 with a cam mostly for a loopy idle
Fi tec fuel injection
Nv 4500 5 speed
Np 205 transfer case
H2 headers to a dynomax ss 2.5 exhaust
H2 wheel and tires (for now)
Escalade front and third row
90’s blazer gas tank with built in pump and sending unit
Omaha orange and gm Pearl white.
Pics are next
DemkoG is offline   Reply With Quote
Old 11-05-2019, 04:41 PM   #2
DemkoG
Re: left over blazer
Old 11-05-2019, 04:46 PM   #3
raggedjim
raggedjim's Avatar
Looks like you have a great start! Can't go wrong with the orange.
Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 11-05-2019, 06:28 PM   #4
jaros44sr
jaros44sr's Avatar
Nice, you are far more talented than me, I fear welding in a patch to fix my rusty rear fender wheel arches
keep up the great work and post up more pics
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-12-2019, 04:07 PM   #5
DemkoG
Thanks for the complements. The orange defiantly one of the best colors for fun cars, I have to admit the colors are left over from other projects as well. Orange is from a Saab sonnet build and a white is from my Waggoner.
The patch panels are not hard just go slow. 1/4 inch at a time not to warp. ans spread it out.
once the shop is cleaned up from painting I will take some better pics.
Old 12-09-2019, 04:28 PM   #6
DemkoG
I was doing a little wiring over the week end so I snapped some pics of the chassis.
Front tow hitch. mounted any thing you want including a step so it is easier to work on the truck.
clearance the frame little for the headers it has been reinforced inside the c channel.
np 205 shifter bracket works as good as the original
and a fun shot of the exhaust
Old 12-09-2019, 06:23 PM   #7
jjzepplin
jjzepplin's Avatar
Those are some real nice leftover parts!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 12-10-2019, 11:10 AM   #8
DemkoG
Thanks but they all are left over parts. The motor is from a totaled Vett of mine. The trans was 2wd from our old plow truck and we have more 205. I hate moving them around. The axels are also form a old plow truck both trucks went to the scrap yard The front tow hitch was for a 2000 f-250 that got a 5th wheel. The exhaust is seconds, had a friend at dynomax that let me buy a box of seconds. so surprisingly not too much has been spent on the truck.
Old 12-31-2019, 03:58 PM   #9
DemkoG
Got the body back on the frame going to finish some wiring, get the doors on block it all out and get it ready for some paint.
Old 12-31-2019, 10:36 PM   #10
rsavage
rsavage's Avatar
Nice!
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 01-02-2020, 12:10 PM   #11
DemkoG
Thank you RSavage
got the filler neck and filler tube mocked up last night. TIGed two pieces of ss tubing the different sizes to make a 45 adapter.
