Old 11-12-2019, 04:54 PM   #1
skip99
skip99's Avatar
Shock crossmember size
51 truck, adding a four link, what size tube should i use for rear shock crossmember? I have 1”x2”x .08”. Seemed thin, so i found a piece of 11/4x 11/4x.17. Hhavent decided what ends of shocks to use either, probably qa1 but thinking , wellding tabs on the tube might be better than drilling through the tube and mounting with a bolt, Opinions?
Tami's 51 build
http://67-72chevytrucks.com/vboard/s...d.php?t=428878
skip99 is offline   Reply With Quote
Old 11-12-2019, 09:19 PM   #2
PGSigns
PGSigns's Avatar
Re: Shock crossmember size
I always used 1 5/8 .125 wall in the drag cars. When we were building drag cars I used a lot of brackets and tabs from these guys. Good quality and service. Still have a bunch of stuff always comes in handy. https://www.aa-mfg.com/
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-12-2019, 10:13 PM   #3
skip99
skip99's Avatar
Jimmy
Good link, thanks
Tami's 51 build
Old 11-18-2019, 12:43 AM   #4
PDW HOTRODS
PDW HOTRODS's Avatar
That 1 5/8 would be fine for a regular shock bar but I think it needs to be stronger for 4 link. It need to support the weight of the truck.
PDW HOTRODS is offline   Reply With Quote
