![]() Join Date: Feb 2013
‘78 K10 - Front Axle Not Centered?
Hey, gang. As I’m working through the Suburban, I’ve noticed that the front axle isn’t centered under the truck. I thought I noticed it a few months ago with stock steelies and smaller tires, but recently put 265/75R16 General Grabbers on it and the off-center of the axle is now more obvious. Right hand tire is proud of the wheel well. Driver side tucked in. Maybe 1-1/2” off center.
It definitely seems like drivetrain-to-frame rather than body-to-frame... I’ve noted a few mentions on forum threads that our 4x4 trucks were built with the driveline offset to the passenger side, but I’m suspicious. I do know the front track is wider than the rear. Any thoughts? Truck rides and tracks nice enough down the highway except for a vibration between 65-75mph I’m chasing. Curious, eh? Here’s a pic of the right hand rubber protruding.
Ryan - WANTED: '60-'66 4X4 Suburban/Carryall Meet 'Earl', '71 C10 Suburban - Sold, but not forgotten... Meet... yet to be named, ‘78 K10 Suburban Daily Driver |
Re: ‘78 K10 - Front Axle Not Centered?
wish I had an answer for you but I don't.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
on my 81 my front axle sticks out on the driver side. I have looked at a lot 4x4 squares and most of them stick out on one side or the other a little bit. When I had my truck aligned they checked the frame on my truck and it was fine. when I did my cab mounts, I could have moved the body over a bit to make the axle the same on both sides but I would have to move the bed, bumpers etc. I wouldn't worry about it.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() |
Thanks, Matt. I’ll see what I can do about not worrying about it. I can be persnickety.
Here’s a good visual.
I looked at my 91 and the front axle might be a little bit offset to the right.
Interesting the "square bodies" aren't really all that square if you're trying to figure out something like this ![]()
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
