Old 12-14-2019, 08:33 PM   #1
me71c10
Disc brake conversion advise
Looking for advise. Going to add disc brakes with drop spindles and keep stock height springs on my 68 Stepside. Will I be able to use stock front shocks? Thanks
me71c10 is offline   Reply With Quote
Old 12-14-2019, 08:58 PM   #2
KMC3420
KMC3420's Avatar
Re: Disc brake conversion advise
Yes, you will be able to use stock length shocks. Drop spindles do not alter the front end geometry because the only change is the spindle wheel shaft is cast higher. If you haven’t decided on a drop spindle brand, I would suggest ECE, made in the USA!!
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 12-15-2019, 07:20 AM   #3
me71c10
Thanks for the feedback. At this time I have drums and a 2/4 static drop. I'm in hopes of converting to disc front with a power booster. ECE is always highly recommended and I plan on checking them out.
