12-16-2019, 08:53 PM | #1 |
GM HEI #41 weights and #375 center plate wanted
Looking for GM HEI #41 weights and a #375 center plate, anyone have some?
Thanks in advance Kirk |
12-17-2019, 08:06 PM | #2 |
Re: GM HEI #41 weights and #375 center plate wanted
anybody?
12-17-2019, 09:15 PM | #3 |
This guy might be able to help https://www.davessmallbodyheis.com/
12-18-2019, 12:01 AM | #4 |
I talked to Dave and he doesn't have any to sell, but thanks bhc41051
12-18-2019, 12:26 AM | #5 |
What’s the appeal for that weights and plate combo?
12-18-2019, 05:18 PM | #6 |
The appeal is a high performance advance curve. There is a certain hei you can buy new that has these already installed. I would have to look up the part number not all are the same and a lot of new hei's are pure junk. I have it in mine and ive been tickled pink, no laziness and it gets up and goes with the old heads.
Also to the other poster , I believe i have a set . I will have to go look in the garage. Maybe two sets Ill see. |
12-18-2019, 08:49 PM | #7 |
So does it makes the 14 degrees mechanical in the dizzy come on faster or slower?
12-18-2019, 10:30 PM | #8 |
Thanks BigTruckDriver that would be great if you do and if you can find the part number to yours also would be great. I was told by Dave to try and find these to rebuild mine, and have heard from others also so I am going to give it a try.
Thanks Kirk |
12-21-2019, 12:45 AM | #9 |
anybody!
12-21-2019, 03:48 PM | #10 |
Your doing this on a 350 dist. Right? It 's been a long time now. If I remember right the #41 are in some of the 305 Dist. or the v6 dist. I have to look at my Dist. holding shelf. As said I think the center comes in some aftermarket set up Dist. for some reason Accel come to mind. You can do some searches on the they Mr. Gasket , Accel, Moroso, MSD, there is most likely 4 or 5 more can think of them.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
12-24-2019, 09:51 PM | #11 |
Somebody has to have some of these?
12-26-2019, 11:56 PM | #12 |
Somebody has got to have some of these?
12-27-2019, 04:18 AM | #13 |
Have you found some sort of a table or book explaining what effect these different numbered parts have on the advance curve? I would be very interested in learning more. Sorry I cant help with those particular parts you are looking for.
12-27-2019, 07:30 PM | #14 |
I don't have a table or book, my buddy told me to look for that set because it is the best combination for SBC 350 engine, so here I am looking for them.
12-27-2019, 11:24 PM | #15 |
Buy a $15 advance kit at AutoZone. Use whatever combo meets your needs. It's stamped steel cookie cutter pieces and springs. I don't think being Chinese in origin matters in this case.
As for being the "best set for a 350" there are a million combinations of 350. The only way you'll know for sure is to put the engine on a Dyno and curve the timing with a distributor machine. Otherwise it's seat of the pants feel and subjective at that. |
12-28-2019, 01:39 AM | #16 |
I was told to stay away from all the kits out there, the only thing that has it in it is the Chevrolet performance HEI Distributor # 93440806, So instead of spending $220 bucks I just want the #41 weights and #375 center plate. I guess that's asking too much. meanwhile I will continue to search junk yards around here for them, until someone tells me they have some I can get from them.
Thanks Kirk |
01-04-2020, 01:04 AM | #17 |
Nobody has any of these? that's hard to believe
01-04-2020, 10:16 AM | #18 |
01-04-2020, 12:15 PM | #19 |
SunSoaked yes I know you don't have any, but there are a few others that might, for example I just received a response from someone who is checking today! but thanks for your emphasized NO.
01-13-2020, 12:02 AM | #20 |
Looking for only the #375 center plate now, I found a set of #41 weights at a out of town junkyard.
02-23-2020, 07:12 PM | #21 |
I hope it's true about the 93440806 dist having these weights as I just ordered one!!!
1996 Silverado ext cab s/b 1986 Silverado s/b 454 t400 -frame off resto hopefully done soon 1976 Silverado cclb dually - getting a cummins asap |
