12-18-2019, 11:10 PM | #1 |
Unusual Axle shaft?
Hey guys, I need some help on this!
Took my 62 C10 in for new gears (3.38). Good news, found out it's a factory posi bad news needed a new axle shaft. Got a shaft and when I took it in we noticed that the end by the c-clip is thicker on mine than the replacement I found. Looked at another shaft and same thing the end is thinner. Any ideas? The original shaft is on the top. Thanks |
12-19-2019, 02:22 PM | #2 |
Re: Unusual Axle shaft?
So what rear is in the truck? Eaton or 12 bolt?
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
12-19-2019, 03:47 PM | #3 |
If total length of the shaft is the same (seats tightly against the center retaining pin when installed) I don't think it should matter.
12-19-2019, 04:09 PM | #4 |
12-19-2019, 04:12 PM | #5 |
12-19-2019, 04:55 PM | #6 |
12-19-2019, 10:47 PM | #7 |
60-66 Nut
Is the replacement axle from a Eaton HO32/33 or from a '63/'64 12 bolt?
12-19-2019, 11:12 PM | #8 |
It was supposed to be from a 60-62 Eaton. I got it from Aspen in AZ.
I'll call my local yard. They came up with the same type. I'll push for specific details. |
12-20-2019, 07:54 AM | #9 |
Where did you find a new gear for the Eaton? I did not know that anyone was making gears for them. Post a picture of what is in the truck. You just never know with these trucks what may have been changed. The thickness of the spud after the C clip is very important that it is the correct thickness. That is what seats the C clip into the spider gear when the cross pin is installed. To thick and the pin will not go in, to thin and the C clip can come out. Your old axle looks like a 17 spline 12 bolt not an Eaton. That may be why the replacement does not look correct it may be for an Eaton.
Jimmy Jimmy
12-20-2019, 10:24 AM | #10 |
Thanks Jimmy, I'll try and find a 12 bolt shaft and see what it looks like.
Those were in the 64-66 trucks? |
12-20-2019, 11:26 AM | #11 |
I think you need one out of a 63-64 I have one and it’s just like yours and it’s out of a 63
12-20-2019, 01:40 PM | #12 |
12-20-2019, 01:41 PM | #13 |
12-20-2019, 01:41 PM | #14 | |
12-20-2019, 01:44 PM | #15 |
I’ll try and get a picture. The shop found the gears for me. 3.38 are the only ones available. I’ll ask where they got them. There is also a guy that goes by mothertruckeraz who has gears for older trucks.
Posted via Mobile Device |
12-20-2019, 03:56 PM | #16 |
mine said yukon gear& axle on the box, who knows who made them.
1961 chevy K10 my build is------------61K10 build |
12-26-2019, 12:54 AM | #17 | |
12-26-2019, 01:23 AM | #18 |
Post Whore
Its definitely not a 12bolt...like above ..maybe ho 32 or 33..
I'm not sure..I think Eaton but at the end of this post the guy says Eaton has bolts close together...http://67-72chevytrucks.com/vboard/s...d.php?t=426871 Then this...http://67-72chevytrucks.com/vboard/s...d.php?t=702889
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 12-26-2019 at 01:36 AM. |
12-26-2019, 10:43 PM | #19 |
60-66 Nut
That is the Eaton HO32/33 which would be original to the truck.
12-27-2019, 12:23 AM | #20 |
What is a bit shorter? Measure to the 1/32" about .030 of an inch or you are not going to get an answer that counts. You cant play horseshoes here. You just may need a thicker C clip
1953 3100 261cu in, sm420, 3.55 torque tube, omaha orange 1964 GMC 1000 series,custom, 305E, sm420 |
12-27-2019, 12:25 AM | #21 |
If you can’t find a axle I have a couple of those rear ends
01-07-2020, 01:23 AM | #22 | |
01-07-2020, 04:36 AM | #23 |
Post Whore
unless I'm missing something ,that's a open diff...not a posi
01-23-2020, 12:05 AM | #24 | |
