Help!!! Where does the fluid go in???
merry christmas Ya'll
Re: Help!!! Where does the fluid go in???
it goes in around that gear. but you need to use an eye dropper.
Merry Christmas to all and to all a good year. |
that's 12 volt starter fluid
you need 6 volt starter fluid
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
They used to supply starter fluid with an applicator for easy installation. Ever since production was moved overseas you can't get the applicator. What's the point of selling starter fluid if you can't use it??? I think the starter rebuilders are behind it all.
BTW, be sure to read your warning labels carefully. I always let my thoughts wander aimlessly when using starter fluid or spray paint.
![]() Join Date: Dec 2009
If you overfill it will make it own drain plug
![]() Merry Christmas. .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Start-ER fluid versus start-ING fluid. They should put different colored labels on those cans.
1951 Chevy Panel Truck |
Here is some for a tractor
that's the stuff they recommend for starter rebuild purposes so start by placing an easy chair nearby, recommended to be behind your work area slightly like you could fall into it when things get too involved, then start cleaning, disinfecting, and eventual disassembly of the starter. vice grips or adjustable wrench is recommended. disassemble and lay the parts out in order and take lots of pics because you will need them after using copious amounts of the starter fluid. then spray everything liberally with the fluid, ensuring to spray extra around the starter fluid drain plug in the rear of the housing.
when you wake up go outside and take a deep breath and congratulate yourself for proper chair placement. order a new starter. |
This is where I fill my aftermarket starter. The dipstick is taped to the side of the can.
