12-21-2019, 04:19 PM | #1 |
WTB 1965 Chevy C10s pulleys
Hello
I’m looking for two pulleys for my 1965 Chevy C10. GM part# 3868451 water pump pulley cast iron GM part# 3791943 Power steering pump pulley Thanks Pete |
12-29-2019, 07:19 PM | #2 |
Re: WTB 1965 Chevy C10s pulleys
Ttt
12-29-2019, 07:22 PM | #3 |
Wow I didn’t think these were hard to find items Somebody got have ha e these pulleys?
12-30-2019, 10:25 PM | #4 |
Luchador
I bought mine here for $45 used; https://www.heartbeatcitycamaro.com/...GM%23-3791943/
12-31-2019, 06:49 PM | #5 |
Hello
Thanks for your help. Pete |
01-01-2020, 11:16 AM | #6 |
Helllo
🥳 Happy New Year I’m still looking for GM part number 3868451 pulley This is the cast iron three groove pulley. I’m having hard time finding one Anyone? Thanks Pete |
01-02-2020, 07:01 PM | #7 |
I wonder if you are searching for the wrong thing. The cast iron three groove water pump pulley is for 327's in 1966. Not used on 283's in 65. In 65, the 283 used a second shallow add-on pulley over the stock single groove pulley to add AC, but even that has nothing to do with you adding power steering to your truck. So unless you are adding factory AC, you don't even need that one. I don't have a shallow water pump pulley for a 283, but do have the cast iron 1966 327-only AC one, but if you didn't know already, you should be sitting down when anyone prices one because they are super rare to find and expensive as a result. The shallow 283 pulley is cheap but also hard to find
My Projects and Toys - All 100% Stock 1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction 1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar 1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock 1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd 1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet 1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight 1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB 1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet 1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet 1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet. |
01-02-2020, 07:53 PM | #8 |
Hello GMCnut
I have a factory ac car. 1965 Chevy C10. I am taking out the 350 and putting in a 327 engine in place of the 350 engine. I am also adding power steering to the mix. Unfortunately I have a complete set up from a mid 70’s truck. Unfortunately I had to buy all the correct pulleys. The ones I have now are for long water neck pump. They don’t seem to line up well. I decided since I have most of the original ac parts that came with the truck. I wanted to put it back to factory look. I had good advice from 60-66, LT1 Burb. I decided to back to somewhat factory original. I have all the correct pulleys. Expect for the water pump pulley. 3791943 Power steering pulley. 3765386 Pulley cast iron crank 3831397 Pulley steel crank I figured it wasn’t and easy item to find. Since no one responded back to me accept for you. I would like to hear how much your want for the pulley if it’s for sale. Thanks Pete Last edited by Blk63vette; 01-02-2020 at 08:08 PM. |
01-02-2020, 08:03 PM | #9 |
Here what I’m working with.
The way it looked when I dragged it home last year. |
01-03-2020, 01:18 PM | #10 | |
01-03-2020, 07:15 PM | #11 |
Hello GMCnut
I am ok with this price. I know these things can take years to find. I appreciate your honesty. Let me know if you take PayPal or check? Thanks Pete |
01-04-2020, 12:33 PM | #12 |
OK - I am going to the building this AM to fetch it. Text me at 256 486 1988 and say you are the guy about the pully and I will send pics and paypal info
