Holes in Lower Control Arm For Sway Bar
Looking for a drawing or template on where to drill the holes for the factory style of sway bar. My lower control arms were not drilled at the factory.
![]() ![]() ![]() Join Date: Jan 2018
Re: Holes in Lower Control Arm For Sway Bar
Had the same situation with my 63. I know this answer isn't what you want, but if you can't get a template, this is what worked for me. I just mocked up the bar at ride height with some c clamps to hold the frame stands up and then positioned it to where I needed it to work. It has been that way since I put it on over a year ago and has been fine ever since
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
![]() Join Date: Aug 2008
Faqs section. TXFirefighter did a great tutorial years ago.
I changed the front suspension on my 66. I put a 79 control arms on it. The bolt holes for the torsion bar are 27/64 diameter and they are 3" apart. From the back edge of the control arm the first hole is 8 3/4. Measure from the top side of the control arm. Hope this helps.
Meant to say sway bar. LOL!!!
Moderator
![]() ![]() Join Date: Aug 2011
The smart thing to do would be to install the sway bar with the end links to determine where your a-arm holes should be.
