Carpet for rear of cab ?
I've heard ACC sells really nice carpet for our trucks.
I see that they also sell a matching carpet tailored, for the rear cab wall It attaches with Velcro, I guess that allows access to the gas tank , if needed. Anyone ever buy one ? The carpet sell for between $59 -$69 depending where you look. Any comments from someone who has installed one, or pics would be great. Here is a description ACC Carpets Original Style Black Rear Cab Wall Carpet with Velcro for all 1960, 1961, 1962, 1963, 1964, 1965 and 1966 Chevrolet C10s. Rear Cab Wall Carpeting Features: - Direct-fit for 1960-1966 Chevy C10s - High-quality loop-style carpeting in factory-correct colors - OEM-style reproduction manufactured from 100% nylon yarn - Helps provide a clean, finished look to the interior - Proudly made in the U.S.A. Last edited by kensblue64; 01-26-2020 at 01:35 PM. Reason: ... |
Re: Carpet for rear of cab ?
I picked up the black one for my '63 when I did a little interior update. It would go behind the tank and attach with some pretty heavy duty velcro. I put sound deadener on the back wall first then installed the carpet. Im happy with mine. I think it helps cut the cab noise down a little as well.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
I got one as well, I like it a lot, cleans things up nicely
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
It's Better With Nitro
Here's what mine looks like...
That looks nice! I'll have to order one now.
What kind of door panels are those ?
They are the factory door panels covered in the same leather that my benchseat and visors are upholstered.
![]() ![]() Join Date: Oct 2014
