01-26-2020, 10:55 PM | #1 |
Front crossmember swap?
I have a 1966 gmc 1/2 ton pickup and I am looking for the easiest cost effective way to get disc brakes and power steering. I have heard you can you the front crossmember from a 73-87 pickup, are Van's also the same? And input is much appreciated! Also looking to fit a 454 in but that may be a whole other can of worms!
01-26-2020, 11:01 PM | #2 |
Re: Front crossmember swap?
FAQ section has all kinds of good info.
01-26-2020, 11:06 PM | #3 |
Im pretty sure 72 and up cross member is a direct bolt on , I plan to do one in the near future on my 65 shorty Bellsouth truck . The power steering is a little more involved but doable .
01-27-2020, 12:46 AM | #4 |
'84 'Burb crossmember fit my '61, but I had to drill some holes. And if I'm going to drill holes, I might as well move the crossmember forward 1". Which I did. And section it, too.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate Last edited by SkinnyG; 01-27-2020 at 01:22 AM. |
01-27-2020, 12:51 AM | #5 |
You can bolt on later model control arms on the 63 and up trucks. You do not have to swap out the cross member.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
01-27-2020, 12:53 AM | #6 |
I just completed a swap like this. I have a 63 C10 that I stuck a 78 C10 front crossmember in. Real easy swap, everything but 1 bolt hole on both sides of the frame matched up.
63 C10 |
01-27-2020, 08:58 PM | #7 |
Vans are NOT the same. They have a wider stance both front and rear.
01-27-2020, 09:01 PM | #8 |
1965 Chevy C10, 2005 4.8L/4l60
73-87 c10, Suburban will work great!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
01-27-2020, 09:25 PM | #9 |
Ok thank you guys for the very useful information I really appreciate it! So Van's wont work but suburbans will? How bout would blazers or Jimmy's?
01-27-2020, 10:47 PM | #10 |
60-66 Nut
Any 1/2 ton 2wd truck based front suspension will work. So yes a 2wd Blazer or Jimmy will work. Regarding the full size vans, the spindle, rotors and calipers will work on your original control arms with a ball joint swap. The van control arms are basically the same as the C10 truck control arms, but the shafts are weird, with a tube on the outside with rubber in between. At least the set I have from a '85 G10 van are. The van steering box will not work as they are backwards from a truck box even though they look the same.
Installing a big block is not that difficult. I've done it about 28 years ago and many, many others have as well. I do make the steering box adapter plates as well and many other products.
