01-27-2020, 05:37 PM | #1 |
Disc Brake Conversion Question
Howdy everyone .
I'm converting the brakes on my '62 to disc brakes all the way around. On the front driver's side, we removed the old spindle, but the lower A-arm won't come back up high enough to allow the new spindle to be put on. The new spindle is about 7/8" longer, so I am not understanding why things aren't bolting back up. Could it be an issue with the torsion bar? If so, is there a way to make it all mate back up. When I put a jack under the lower A-arm, it raises that whole side of the truck. Thank you in advance, Nate |
01-27-2020, 08:55 PM | #2 |
Re: Disc Brake Conversion Question
I'd say the preload on the torsion bar is causing it all right. Even coil spring front ends need the spring compressed to safely bolt up a spindle.
01-27-2020, 10:13 PM | #3 |
Who Changed This?
Having somebody sit on the fender to bring it down is an easy way. You could of course loosen the tension bolt on the torsion bar. It'll have to be aligned when you're done anyway, so you really don't lose anything either way.
01-28-2020, 10:33 PM | #4 |
When I did mine I loosened the t bars (removed the tension) and placed a floor jack under the control arm to bring it up. hope this helps
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
01-29-2020, 01:35 AM | #5 | |
Have a 327 that I bought from a neighbor (came from a '66 C20) that's currently at a race engine shop up here and is getting mag'd, etc. They're also ordering the rebuild kit for the kids and I to rebuild before we put it in the truck. Wife's losing her mind as I buy parts.... but I'm happy.... and my students are too. Life is pretty good. Oh, and finally got a name for the truck..... Spoiled Milk |
01-29-2020, 06:37 PM | #6 |
