Old 01-29-2020, 06:25 PM   #1
sl66
sl66's Avatar
moving column shifter
Anyone have experience or know how to move a shifter lever up on a 3 on the tree application, problem is in 1st and 2nd gear the lever touches/lays on my right leg/knee ( being 6-4 probably doesn't help ) , would like to rotate it up but not sure how or if it is possible without messing up the rest of the linkage ? truck is a 66 C-10
sl66 is offline   Reply With Quote
Old 01-29-2020, 06:28 PM   #2
dracko
dracko's Avatar
Re: moving column shifter
Could you take the lever off, heat it up with a torch and bend it so it sits higher?
dracko is offline   Reply With Quote
Old 01-29-2020, 06:39 PM   #3
sl66
sl66's Avatar
I thought about that as a last resort of course I would imagine it would ruin the chrome
Old 01-29-2020, 07:11 PM   #4
dracko
dracko's Avatar
Yeah that’s true, I haven’t dealt with a column shift so I probably have no business commenting but could you try bending it cold. A little bend where it attaches to the column results in a lot of gain at the handle.
Old 01-29-2020, 07:17 PM   #5
sl66
sl66's Avatar
yeah, i guess i could put the end in a vise and bend it that way, will give it a try if there's not a mechanical way of rotating the whole column, thanks for the advise tho , i appreciate the input , grew up driving mt dads 65 and don't recall the shifter being so low
Old 01-30-2020, 09:26 PM   #6
AcampoDave
AcampoDave's Avatar
Mines not that low. I'm 6'4" and have no porblem, I wonder if something else is going on
AcampoDave is offline   Reply With Quote
Old 01-30-2020, 09:32 PM   #7
DPowers
DPowers's Avatar
Can you post a picture?
DPowers is offline   Reply With Quote
Old 01-30-2020, 10:10 PM   #8
cwcarpenter98
cwcarpenter98's Avatar
When I had the regular 3 speed in my 63, the shifter did not hit my knee in 1st or 3rd.
After I swapped in the 3 speed overdrive trans, the shifter stayed in the same spot in 3rd, but now bumps my knee in 1st. Kinda weird, but I have no idea how to change it
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 01-30-2020, 10:28 PM   #9
DPowers
DPowers's Avatar
Is there any adjustment room on the column?
Old 01-30-2020, 11:24 PM   #10
SkinnyG
SkinnyG's Avatar
The two bolts thread into a wee plate inside the column. I don't remember how much room you'd have to redrill with the column rotated, but rotating the column is also going to move your signal stalk.
I would bend the lever, but I have not looked at the shift mechanism (and it's even been YEARS since I've driven 3-speed column).
Is it possible to alter the linkages to the transmission (presumably threaded/adjustable) to make the shifter be higher?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 01-31-2020, 09:31 AM   #11
sl66
sl66's Avatar
I'll get a pic this weekend , it may have been altered by the previous owner, I was afraid that by trying to rotate the whole assembly would cause issues down the Line RE.. linkage, turn signal stem etc.... dracko probably right just puttin a slight bend in the base of the lever would do wonders......
Old 01-31-2020, 11:48 PM   #12
AcampoDave
AcampoDave's Avatar
Perhaps adjusting the rods here would alter the throw of the shifter. Mine are more or less in the middle.
Old 02-03-2020, 10:24 AM   #13
sl66
sl66's Avatar
will check rod locations that maybe how to rotate it back up,attaching a pic not sure if I did it right tho
Old 02-03-2020, 03:04 PM   #14
Ken Cook
Ken Cook's Avatar
I'm thinking, put it in 3rd, loosen at the rod connection and put the shift lever a little higher then re-tighten. Then do the same with 1st.
It might be easier to do the same thing with 2nd and reverse. That way you can see the end of the slot on the moving part on the end of the column. see photo in post #12
Ken Cook is offline   Reply With Quote
