01-30-2020, 01:32 PM | #1 |
exhaust routing muffler placement advice?
Mocking up the dual exhaust on my 65. Suspension is a 3/4 drop. I have shorty headers and so far I've run the exhaust straight back through the trans crossmember to just behind the cab. Not using an h pipe. As you can see I've got a muffler propped up where I figure it should go. Right now its sitting 2 1/2" below the bottom of the wood floor. It'll be a challenge to jog the pipe in and up to the muffler inlet. Once I get the mufflers on and the truck is driveable I'll trailer it to the muffler shop to make some tail pipes to exit behind the wheels. I have no idea for hangers. How does this muffler placement look? Where/how should I do hangers?
01-30-2020, 03:44 PM | #2 |
Moderator
Re: exhaust routing muffler placement advice?
Does the driveshaft have clearance?
01-30-2020, 06:20 PM | #3 |
62 with Super 40s turned up, not flat
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
01-30-2020, 07:45 PM | #4 |
01-30-2020, 11:06 PM | #5 |
60-66 Nut
IMO, mufflers with an offset inlet and center outlet work better.
