02-01-2020, 10:30 AM | #1 |
Transmission x member for 61 ideas
I planning on putting a th350 /350 in my 61 apache I’m looking for ideas/pictures how other members have built this x member,the truck originally had a 4 speed on the floor,I have installed a front x member from a 72 chev and I’m going to use the 72 motor mounts,it has 2 inch lowering springs and drop spindles,I’m pretty sure I will have to remove the original bellhousing mount that the old manual transmission was mounted on .and I’m also looking for ideas on front shock mounts with the setup I have going on,or even where to get shocks
02-01-2020, 01:04 PM | #2 |
Re: Transmission x member for 61 ideas
I know its manual, but you can make one for auto out of tube. First one was box tube bolted to bottom of frame. See my build for more pics
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
02-01-2020, 01:22 PM | #3 |
I copied LVPhotos
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
02-02-2020, 11:17 AM | #4 |
Thanks for pictures,very helpfull,I was wondering if you had to modify you’re park brake at all ,any advice would be awesome,I did check out you’re build LV,only thing wrong with that build is,it’s not parked in my garage lol
02-02-2020, 12:15 PM | #5 |
I made sure the linkage stuff clears, but I have not connected it up yet. I'm confident it will work, but my trans is also raised quite a bit for better driveline geometry at a very low ride height.
02-02-2020, 05:35 PM | #6 |
No mods to brake set up, even with the up 2" fwd 2" Porterbuilt set up
