Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 02-02-2020, 10:43 PM   #1
CarolinaHD
Moderator
CarolinaHD's Avatar
King pin slop/play 1967 c50
First time working with a kingpin style axle so bear with me. Is there a way tighten the kingpins without replacing/rebuilding it? 1967 c50 5000lb front axle with only 66,000 miles. I already found all the parts to rebuild it just wondering if I can tighten what's there. The service manual was of zero help.
Alex
1967 C50 292ci Lumber truck
1967 C50 292ci Dump truck
1967 C60 366ci Fire truck
CarolinaHD is offline   Reply With Quote
Old 02-04-2020, 04:25 PM   #2
CarolinaHD
Moderator
CarolinaHD's Avatar
Re: King pin slop/play 1967 c50
Bueller...
Alex
Old 02-04-2020, 05:08 PM   #3
Campbel45
Sorry CarolinaHD, I'm not sure. If you don't have much luck here you could try the stovebolt forums
Campbel45 is offline   Reply With Quote
Old 04-26-2020, 11:23 PM   #4
rkn463
rkn463's Avatar
I know this is an old thread, but seeing as how no one ever answered...
I had a 5000lb axle apart and there was no adjustment for the king pins. Just the bushings or oversize bushings if it is too worn. In my case I was upgrading to disk brakes and had the axle bored larger for newer larger pins that fit the 1989 knuckles.
-Richard
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
Old 04-27-2020, 09:17 AM   #5
CarolinaHD
Moderator
CarolinaHD's Avatar
Yep forgot to update this after i rebuilt the front end. I found a kit by stemco that doesn't use plastic bushing and you dont have to ream it out. Worked great and no slop now.
So you reamed the factory 5000lb axle bigger and the knuckles and everything swapped over no issues?
Alex
Old 04-27-2020, 09:19 AM   #6
CarolinaHD
Moderator
CarolinaHD's Avatar
Pics
Alex
Old 04-27-2020, 09:40 AM   #7
HOTRODSBYCHIP
Do you have a web address for stemco?
HOTRODSBYCHIP is offline   Reply With Quote
Old 04-27-2020, 12:19 PM   #8
txagincali
I was going to follow what Richard (rkn463) had done to his truck and was using axles off of a 1988 Topkick but never went through with it. Going 4wd with a Dana 60 now instead, but I do have the complete front axle off the 88 with hydraulic brakes, leaf springs, hangers, 22.5" wheels & tires, steering arm etc available for Free if anyone here would like to have there try at it.
1963 Olson Grumman Bread Van - Possible Suburban Swap (sporadically worked on to strip paint)
1969 GMC C10 Pickup SWB Stepside (heart transplant)
1969 Chevy C50 Fire Truck converted to Utility Truck being built into Pickup Truck (newest addition, accumulating spare parts)
1972 GMC K5 Blazer 4x4 (sporadically being worked on, accumulating parts)
txagincali is offline   Reply With Quote
Old 04-27-2020, 07:15 PM   #9
CarolinaHD
Moderator
CarolinaHD's Avatar
K51g stemco
http://www.stemco.com/parts/details/?id=866
Alex
Old 04-27-2020, 07:16 PM   #10
CarolinaHD
Moderator
CarolinaHD's Avatar
Of course you're on the other side of the continent lol thanks for offering up.
Alex
Old 04-28-2020, 08:44 PM   #11
1976gmc20
only 66,000 miles
You sure...? Could be 166K or 266K
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 04-28-2020, 08:52 PM   #12
CarolinaHD
Moderator
CarolinaHD's Avatar
Yep, this baby was kept in a shed and has registration cards back to the late 70s with the correct mileage
Alex
Old 05-01-2020, 11:18 PM   #13
rkn463
rkn463's Avatar
Yes, I was using an 89 C60 as a donor for my 68 body. The 89 axle was 6" wider than the 68. It turned out the steering knuckles from the 89 "fit" the 68 axle after overboring the kingpin holes in the 89 axle by .0070. Check out post #14 in my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
By the way, thanks for the info in your tread about the Bosch brakes. My build is stalled right now due to a problem with the auxiliary backup pump for my hydroboost and a complete lack of available replacement. I'll likely swap over to the Bosch style booster.
-Richard
Old 05-02-2020, 05:53 PM   #14
1976gmc20
They must have never greased it
I have no clue how many miles my 65 c/50 had back in the 1980s when I owned and ran it. The speedometer didn't work for a long time before I fixed it. I was guessing that it was on it's third engine/second rebuild. It could have had work done to the front end but in all the rough miles that I put on it, I never had any issues with the front axle and steering.
Old 05-04-2020, 09:52 AM   #15
CarolinaHD
Moderator
CarolinaHD's Avatar
According to the man I bought it from, their mechanic rebuilt/replaced alot of brake parts in 2004 right before he died.(which is why the truck sat for so long they had no one to work on it).
Best I can figure is there was a little slop and he thought replacing the factory bronze bushings with the cheap Moog plastic parts would tighten it up? I'm sure it did for about a week lol.
Alex
