03-21-2020, 02:33 PM | #1 |
1970 GMC 1 Ton Front Disc Brake/14 Bolt Conversion
I've been working on this for about 4-5 months now getting all of my Internet Engineering Calculations checked and re-checked, parts bought etc.
Wednesday of this week my buddy Curtis called and said he was ready to dive into it with him doing the work in his shop, with me mostly in the way and lending a helping hand when and where needed, for the most part it went pretty smooth with no major hiccups. Finished it up yesterday THANK YOU CURTIS!!!! I made notes along the way to pass on with Otis to my 2 sons for reference in the future, they will have to sock fight it out as what to do with Otis as I play no favorites. I for one find a lot of these threads on conversions (not all) really lacking in detail so I thought I would pass along my notes rather than retype it all with hopes that someone can use the info. It may be a little too much detail for some of you but my real intent is for this info to follow the truck into the future. Hope its not too long of a read for you guys n gals. 1970 GMC C35 1 Ton Cab and Chassis Flatbed Converted to Front Disc Brakes And Corporate 14 Bolt Rear Drum Dual Rear Wheel Differential. 3/20/2020 All conversion components are from a 1986 Chevrolet C30 Dual Rear Wheel Cab and Chassis 1 Ton front disc brake suspension cradle and Corporate 14 Bolt 10.5" rear differential that I purchased unless noted. Conversation Mileage was 96,500 Odometer Miles. What I used to complete the front disc brakes transition is as follows: 86 Stock C30 Complete Front Spindle left and right Rotor Assembly’s separated at the upper and lower ball joints and tie rod ends. They were disassembled, cleaned, checked and bearings re-packed with hi-temp bearing grease. 86 C30 Front Disc Brake Pads: O’Reilly P/N - BB2 MKD149 (1) set of 4 pads required. 86 C30 Front Disc Brake Calipers: O’Reilly P/N’s - BC 18-4166 (1ea) Right Side BC 18-4167 (1ea) Left Side 1972 GMC C35 front disc brake flex hoses were used from the caliper banjo bolt to male fitting line connection at the frame. The frame end of the hose had to be turned down to fit thru the securing ring at the frame. Other than that they fit fine and are the correct length. O’Rielly P/N BH71305 (2) required. Brand new Mev-Tech (Original Grade) Upper and Lower Control Arms to fit 86 C30 Cab and Chassis. They came supplied with Moog upper and lower ball joints and upper and lower control arm shafts and shaft bushings already installed These bolt right on the existing 1970 GMC C35 front suspension cradle no modifications required and the 1970 GMC C35 front coil springs were re-used with no issues, they fit perfectly into the new lower control arm spring saddle bucket. The 86 springs were a little taller and a little beefier and I did not want to raise the existing ride height if possible. The existing 1970 GMC C35 front shocks bolt right up with no issues. Monroe front shocks: P/N 34817( 2) Required Mavtech Control Arms are as follows: (1) Left Side Upper/Lower required (1) Right Side Upper/Lower required Lower Arm P/N GS9703 left side Lower Arm P/N GS9702 right side Upper Arm P/N GS9701 left side Upper Arm P/N GS9700 right side 86 C30 Upper Ball Joints: Moog K6122 (2 Required) These are listed here for future maintenance purposes when replacement is required. 86 C30 Lower Ball Joints: Moog K6129T (2 Required) These are listed here for future maintenance purposes when replacement is required. I used the existing 1970 GMC C35 steering cross control bar/link, I installed a new Pittman Arm and new Idler Arm to fit the 1970 GMC C35. Parts are as follows: 1970 GMC C35 Pitman Arm (steering box splined shaft to steering cross link) Moog P/N K6131 (1) Required 1970 GMC C35 Idler Arm (frame bracket to steering cross link) Moog P/N 57192JV (1) Required 86 tie rod ends must be used, they bolt right to the 1970 GMC C35 steering link and are a factory fit for the 86 spindles parts are as follows: 86 C30 Outer Tie Rod Ends: Moog ES409RT (2 req) Use 1 each Side 86 C30 Inner Tie Rod Ends: Moog ES409LT (2 req) Use 1 each Side 86 C30 Tie Rod Adjuster Sleeves (2req) ACDelco P/N 46A6004A or GM P/N 88876894 Use 1 each side What I used to complete the 1986 14 Bolt Rear Differential swap is as follows: The 86 14 bolt was opened and inspected for wear, it was found to be a 4.10 ratio in excellent condition with good tooth contact pattern and backlash within specification. A new pinion seal was installed everything re-checked again and the rear cover reinstalled with silicone sealer. The 86-14 bolt rearend bolts right into the existing 1970 GMC C35 H072 rear differential factory mounting points using the existing U-Bolts. I had earlier relocated the shock absorber mounting locations on the 14 bolt to accept the existing 1970 GMC C35 rear shocks (both forward facing) These weld on shock brackets can be sourced thru ebay or Amazon. RuffStuff Specialties R1988 Jeep Lower Axle Shock Mount (Pair) Note: I chose these mounts because they pitch sideways about 10 degrees. The center section carrier housing of the 14 bolt is wider than the H072 and also has pressed in axle tubes unlike the welded smoother transition H072 housing. The right or passenger side you can get right on the money, the left or drivers you can get within 3/4” and still leave enough weld area next to the axle tube sleeve for proper attachment. You also have to tilt them a little to get the shock mounting bolt level with the axle tube centerline or parallel with the ground, however you want to look at it. A good wire feed welding machine is the ticket here to keep fitment to a minimum amount of work. Monroe Rear Shock P/N 34803 (2) Required A new brake line center flex hose was installed: Dorman P/N H80967 ACDelco P/N 18J2119 No modifications to the driveline length were required. 2 new U-Joint retainer straps to fit the 14 bolt pinion yoke were required for the existing U-joint to bolt up to it. U-joint retainer strap kit: ACDelco p/n 45U0508 U-Joint at the rearend/driveline yoke was almost new and the correct application so it was re-used. A/CDelco U-Joint P/N 45U0123 Listed for future maintenance Wheel mounting surface to Wheel mounting surface of drum faces is 63” Spring pad mounting pads are 40” center to center Drums are 13”x3-1/2” Dual Rear Wheel configuration Gear Ratio is 4:10 Open differential (no positraction) Truck tachometer now reads 1950-2000RPM @ 55MPH in 4th Overdrive. Brake Drums were turned and trued up. New brake shoes: A/CDelco P/N 14452R 13”x 3-1/2” New rear wheel cylinders: (2) Required API P/N 53623MY-13x3-1/2” Brake Shoes New Axle Flange Seals/Gaskets: FelPro P/N 55350 New master cylinder and proportioning valve for a 1972 GMC C35 original equipment Disc/Drum set up was used. Master Cylinder: O’Reilly P/N NMC11302 Proportioning Valve GM Style Disc/Drum - PV2- Classic Truck eBay sourced. The only modification required was the push shaft out of the existing dual diaphragm booster was for a drum/drum master cylinder so it was to long and was shortened 5/8”+/- and tested for proper clearance with contact putty and contact grease. In a future maintenance application replace the Vacuum Booster with a 1970 GMC C35 dual diaphragm Original Equipment application and replace the Master Cylinder with the O’REILLYS P/N as above then re-use the existing modified push shaft and there should be no fitment issues. Another option is to replace as a matched unit both the master cylinder and brake booster for a 1972 GMC C35 disc/drum assembly. Last edited by Sheepdip; 04-20-2024 at 12:43 AM. |
03-21-2020, 05:54 PM | #2 |
Re: 1970 GMC 1 Ton Front Disc Brake/14 Bolt Conversion
nice write-up, thanks for documenting everything and sharing. What trans do you have in this truck? A C30 is on my bucket list... Preferably weighted down with a Mitchell camper.
03-21-2020, 05:58 PM | #3 |
03-21-2020, 06:48 PM | #4 |
very nice!
03-21-2020, 09:30 PM | #5 |
Thank you for taking the time to document this Great info.
This will be a very useful Thread. This list you made / I'm almost certain , Is my plan for the front brakes. I purchased rotors & calipers and spindles from a Pick/n/pull. This way I will have a mock-up set and then use rotors and calipers for the core charge When I'm certain that's my plan. One Question: Is your Front calipers the style with the slide in clip like the picture below? .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
03-21-2020, 10:24 PM | #6 | |
I did not research it too much since I had all the parts in front of me, but my rotors were 1-1/4" thick, which I think was considered heavy duty. Not sure maybe somebody in the know can chime in. I also got lucky that they were new surface wise, they had just sitting gathering surface rust so they cleaned up with light cuts. |
03-22-2020, 10:22 AM | #7 |
Sheepdip-
Thanks for taking the time to document and share that info with us. I am planning on doing the 14 bolt swap on my 1 ton in the future so was particularly interested in that information Ron
1972 C30 Cheyenne Super 1971 C10 (Parts truck) |
03-22-2020, 11:03 AM | #8 | |
Like I had stated earlier I always found a lot lacking on accurate info on these swaps.....Good Luck on that swap out. |
02-11-2024, 08:05 PM | #9 |
Nice work.
02-12-2024, 06:36 PM | #10 |
Thanks Dan. I just realized looking at the date on this thread that it has been 4 years ago that the change over took place, time fly's when your having fun!
Still the best thing I did to this truck. |
02-12-2024, 07:02 PM | #11 |
Where I live a lot of guys have flat beds. Yours is just outstanding and would shame the new ones today…
71 C-20 07 Magnum RT AWD |
02-14-2024, 12:39 AM | #12 | |
I get an inquiry ever now and then as to if it's for sale, if they are serious I don't or will never know, because I inform them it's not for sale. I have spent a lot of time and money making Otis a good solid everyday driver/work horse, and my personal theory is why do all that for someone else enjoy the benefits of a nice solid truck. |
