03-27-2020, 12:42 AM | #1 |
Shocks
Hello,
I lowered my 1969 burb 2 1/2 spindles and 4 inch springs. Trying to figure out shocks for the front. I would like to install KYB but not sure which one to get to fit properly. If anyone can tell me what they are using maybe I can cross reference and get the correct size. Any help greatly appreciated |
03-27-2020, 10:43 AM | #2 | |
Re: Shocks
I personally like Bilsteins on C10's.
03-28-2020, 01:11 PM | #3 |
Re: Shocks
03-28-2020, 02:07 PM | #4 |
Re: Shocks
Let me re-phrase the question. Is that 2.5" spindles and 4" springs on the front?
OR.... 2.5" spindles on the front & 4" springs on the rear?
03-31-2020, 09:25 PM | #5 |
Re: Shocks
If you have drop springs and drop spindles up front you can use stock fitment shocks and just move the shock mount farther up to regain full travel. I did this on a '66 with stock fitment Gas-A-Just shocks and it worked great. Rode as good as dad's completely stock '66, actually better since it had sway bars and a lower center of gravity to minimize excessive body roll and pitch. It did have 15" wheels with 215/75 tires, so maybe the tall sidewalls kept the shocks from feeling too stiff like Scoti describes.
I modified a set of Currie axle mounts and bolted them to the frame rail.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
