Old 12-10-2003, 02:24 AM   #1
Brian Ringer
Junior Member
Brian Ringer's Avatar
longer wheel studs for 72K5
I bought eagle 589 rims for my 72K5 and the wheels studs arent long enough. Any longer studs available?
Brian Ringer is offline   Reply With Quote
Old 12-10-2003, 03:11 PM   #2
bayarea k5
i have the same rims on my '72 (15x12) and they went after gringing away some of the caliper. they did not fully seat because of the clearence issue. i found where the contact was and grinded a little off each corner of the caliper. if i could do it over i would of went with a larger rim diameter. if you want longer studs, you can usually get them at a regular parts store. if not, try a wheel specialist like wheel works or americas tire. first you should make sure that there is no contact with the disc break components and the rim. i hope this helps.
72 k5
6" suspension
2" body
16x35x15 BOGGERS
bayarea k5 is offline   Reply With Quote
Old 12-11-2003, 06:56 PM   #3
72 Blazerman
Chevelle Nutt
72 Blazerman's Avatar
You should be able to get some from your local speed shop. I know Moroso makes them and I think ARP makes them too.
Doug
71 CST Blazer 4X4, 350, on da tree
81 Blazer 2wd 350 350
99 F*** Ranger, I know, I know but it's cheap transportation
83 Mustang GT 5.0 4 speed loaded
"got cubic inch?"
72 Blazerman is offline   Reply With Quote
