05-07-2020, 08:44 AM | #1 |
Crankshaft End Play
So i was messing with my 5.3 yesterday and was wondering if the crank had any up/down/ side to side play and although it didnt it did have some front to back movement. I know it is supposed to have a little bit but how much is too much? the engine supposedly has 175k on it and was pulled from a tahoe for oil pressure problems. I would like to just rebuild it but for the cost of a budget rebuild you can buy another JY engine right now. Thanks
05-07-2020, 07:35 PM | #2 |
Moderator
Re: Crankshaft End Play
Standard spec for end play is
End Play: 0.04-0.2mm /0.0015-0.0078 5.3 oil pressure issues is most likely excess bearing clearances and bypass valve issues in the oil pump...
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
05-08-2020, 07:48 AM | #3 |
Thank You. I am going to check everything out just for peace of mind but almost everything I have read has said oil pump or gallery valve or some o-ring on the pump. seems like these things will last forever other than the oil pump issues.
05-09-2020, 05:19 PM | #4 |
my 2002 suburban with 5.3 delvoped oil pressure issues this year at 238k miles it turne dout to be the pick up tube oring a 4 dollar oring now oil pressure is at 70psi idle, my 2000 tahoe with 5.3 at 369k when i replaced engine and transmission still had 60psi at idle and had never had anything done inside but was running and leaking more oil then bp did in the gulf..... so its hard to say why your lost oil pressure but 5.3s area dime a dozen in wrecking yards
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
