05-08-2020, 07:55 AM | #1 |
I can't be the only one confused about 2nd design bolts!
I'm building an lq4 and replacing the stock TTY bolts with stock bolts. Problem is I can't get the old conrod bolts out. I don't want to smash-whack them out, if I slip I ruin the fractured rod surface. Any Ideas? And no, new forged rods with ARP bolts isn't an option! That'll feed my kids for a month and a half!
1969 Chevy C/10 Stepside, Short Box. LQ4/4L80E swap in progress! (Donations being accepted!) |
05-08-2020, 09:05 AM | #2 | |
Re: I can't be the only one confused about 2nd design bolts!
05-08-2020, 12:04 PM | #3 |
Post Whore
https://www.onallcylinders.com/2017/...nes-need-know/
Copied this Which LS Fasteners are TTY? On a GM LS engine, the cylinder head bolts are TTY and cannot be re-used. The connecting rod bolts are also TTY, but can be tightened up to three times for bearing checking. The balancer bolt is also a torque-to-yield fastener.
05-08-2020, 08:15 PM | #4 |
And if I recall correctly if you replace the rod bolts with aftermarket you have to resize the con rods because the new bolts tighten differently. Check over on LS1tech.
05-09-2020, 10:06 AM | #5 |
Pull 1 bolt out, put new bolt in and torque. Do that 16 times. Many people have done it this way with no issues on a stock bottom end. This is assuming you don't have the bottom end torn apart.
Why are you wanting to replace the bolts in the first place? Stock bolts are fine if you don't see >6500rpm consistently. ARP rod bolts are around $100, and I see no need for forged rods unless you're after huge HP.
1967 C10 SWB 6.0 LS swap in progress 2011 CCSB Duramax 4x4 |
05-11-2020, 07:06 AM | #6 | |
The problem is, the bolts don't just come out. There is some sort of sleeve on the shaft of said bolt and pressed into the cap off the conrod. My question is had anyone else delt with this and what did you do?
05-12-2020, 08:58 AM | #7 |
Post Whore
Found this video... https://m.youtube.com/watch?v=F8ISw9Q3CrU
He just basically screws the bolt out..
05-18-2020, 01:04 PM | #8 |
tap with a plastic mallet they will knock out.
use soft face something so you don't affect the fractured surface
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear |
