Old 12-14-2003, 03:10 PM   #1
'68 K-10
'68 K-10's Avatar
Question need lots of advice
Hey everybody. I need some help with a few things. First is why would a truck have a higher hump? i have a 4 wheel drive cab with a low hump and a 2 wheel with a low hump, and i want to put the two wheel drive cab on the 4 wheel frame. i was wondering if because my 4 wheel is manual if that is why it is low because i am going to put an automatic in it. i just want to make sure the 2 wheel drive cab will work b4 i do all the work to it. also i went and bought a new crossmember for the automatic i want to put in, and it is almost exactly the same as what my manual was sitting on. for right now thats all the questions hope you guys can let me know what i need thanks
~JAKE~
'68 K-10 IN PROGRESS OF A FIRST TIME RESTO. ANY ADVICE IS NEEDED. I'M IN NEED OF SOME PARTS TRUCKS NEAR MICH. THANKS
'68 K-10 is offline   Reply With Quote
Old 12-14-2003, 03:38 PM   #2
Blue_71
Bloo
Blue_71's Avatar
all 4x4 are high hump from the factory. has to be because of the t-case. TH400/BB and 4 speed trucks are supposed to be too
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 12-14-2003, 05:44 PM   #3
nu2-72
Hello Jake. Check your post. It confuses me.
As stated, all 4x4 cabs are high hump. How did you determine that you have a 4x4 cab?
And the purpose of the high hump is clearance for one and on the manual trucks it can be unbolted for access to the tranny shifter.
That is another thing. Low humps are part of the cab floor. High humps are a seperate hump and bolt in.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 12-15-2003, 01:37 AM   #4
'68 K-10
'68 K-10's Avatar
well the cab that i took off from my 4x4 frame is bolted but it doesnt appear to be any higher than my 2wheel drive. is it possible to cut out a low hump and weld in a high hump
Old 12-15-2003, 01:39 AM   #5
dinnut
dinnut's Avatar
i dont see why cant take out a small hump and bolt in a high hump. high humps bolt in. the small humps are welded in
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-15-2003, 02:15 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
th 2 wheel drive 1/2 ton has smaller cab mounts. The 3/4 ton and one ton trucks have tall mounts, as do all 4X4s.
The high hump is in fact a bolt in on most all cabs. (never seen a weld in...but I have heard of it) Cut out the low hump, leaving an inch or so to bolt the new one to, and then blot it in with some kind of sealer to keep the water and crap out. The Right Stuff would work great...just don't expect it to come out very easily.
Old 12-15-2003, 02:17 AM   #7
Class of 69
Class of 69's Avatar
Cutting out the low hump cab for a high hump is fairly common. As long as you are changing to an automatic, you may not need the high hump. Are you planning on a body lift?? If so, you definately don't need the high hump.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 12-15-2003, 11:02 AM   #8
nu2-72
Trust me, with Bondo or a welder, anything is possible.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 12-15-2003, 12:15 PM   #9
Dean
Dean's Avatar
I've cut the small hump out numerous times and boltted in a high hump. use the high hump piece for a template before you start cutting. It is not a big deal.
Dean is offline   Reply With Quote
Old 12-15-2003, 02:17 PM   #10
'68 K-10
'68 K-10's Avatar
Thanks guys. I do have a 3 inch body lift so i guess it doesnt matter if the cab is high or low it will still work. since i have that figured out now for my other question do i need a different crossmember for an automatic tranny>?
Old 12-15-2003, 02:38 PM   #11
nu2-72
My book shows no.
67-69 Ser. 10-20 (4wd), Blazer
71-72 Blazer (K) ( exc. Muncie 4-spd., T.H. 350) 3889205
67-69 Ser. 10-30 w/AT (exc. 4wd).
71-72 Ser. 10-30 )Conv., D-D) Blazer (C) w/AT 3953849
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 12-15-2003, 02:45 PM   #12
'68 K-10
'68 K-10's Avatar
ok, thats what am thinking is that they use the same one because i went and bought one and it is the same as the one that is on there that held up my manual, thanks i'll bring the other one back
Old 12-15-2003, 02:49 PM   #13
mrein3
mrein3's Avatar
I read a web article where a guy swapped a 4-speed/NP205 for a th350/NP205 and used the same cross member.
I personally swapped a 3-on-the-tree/NP205 for a th350/NP205. I did nothing to the crossmember other than use the fire wrench to remove the factory rivets which I then replaced with bolts.
Every thing I've read or observed tells me all 67-72 4x4 tranny crossmembers, with any transmission and the NP205 transfer case, are the same. GM made up for any differences with the adapter between the tranny and transfer case. The adapter is the piece that actually bolts to the cross member.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 12-15-2003, 02:53 PM   #14
'68 K-10
'68 K-10's Avatar
i wish i woulda asked b4 i bought the crossmember lol oh well i can never have to many parts thanks guys...
