08-17-2020, 09:46 AM | #1 |
under table storage
More shop cleanup/organizing this weekend. The welding table has always been a catch-all, from something setting on top to the drop cuts of metal underneath. Here's a sample...
So when we got it to this stage, I really didn't want to put the metal storage back underneath on the floor. It prevents a good sweep down and goes downhill quickly. So Mike and I talked about making a shelf under the table and we put some more leftover scraps to good use. 1" square tubing was used to make a support framework and welded to the existing legs. Then a scrap piece of diamond plate is used for the shelf. As we didn't want things falling off the side of the shelf, ends were formed in our radius brake.. The diamond plate was too thick for our mag brake or the press brake but this bent it just fine. A couple of 1/8 pop rivets into the front crossbar keep the shelf from moving... All loaded up, and still good access below for the vacuum cleaner/sweeper.
Robert |
08-17-2020, 10:03 AM | #2 |
Post Whore
Re: under table storage
Your table looks kinda like mine does...seems to be a catch-all...the one I built over at dad's house I made a shelf under it and it helps...never did add a shelf to mine...but will do it sometime..
