Old 09-20-2020, 11:33 AM   #1
4byfour
Bed disassembly question
Thought I would ask the question here on how to get the top 2 screws out of the front of the bedside when they are rusted and stuck. I know I can weld a nut onto them,just wanted to see if there was an easier way that I hadn't thought of.
4byfour is offline   Reply With Quote
Old 09-20-2020, 11:42 AM   #2
kwmech
Re: Bed disassembly question
Hammer Impact Driver and maybe some heat from the backside on the threads
Old 09-20-2020, 12:16 PM   #3
tinman_local2
I use a #3 Philips tip in a small impact along with some heat. Just go easy with the impact so you don't strip the head.
tinman_local2 is offline   Reply With Quote
Old 09-20-2020, 01:21 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
I agree with the impact, and the heat is really important, even if all you have is a hand held propane torch. Get it as hot as you can and then let it cool for a minute or so before trying it. I usually hit them with some penetrating oil after they cool a little, then the impact driver.
LockDoc
Leon
Old 09-20-2020, 02:24 PM   #5
tinman_local2
LockDoc
Couldn't have said it better myself. Works nearly every time.
Old 09-20-2020, 03:32 PM   #6
4byfour
You guys are the best. Got them out with the heat and impact. Appreciate you all!
