10-05-2020, 03:26 AM | #1 |
Pulling motor question
Just wondering how you guys do this, with the head still on or removed. I just could not get enough lift with this engine hoist. Had to remove the head to lift the motor high enough to roll the truck back.
Was hoping I could put the entire motor together before I dropped it back in, but I don’t think that’s going to work. Would be even better if I could bolt the trans up to it too, and drop everything together.
1963 C20, small window, long bed 292, 4-speed |
10-05-2020, 05:26 AM | #2 |
Who Changed This?
Re: Pulling motor question
You could let the air out of the front tires, or take the front tire and wheel assemblies off and put the suspension on blocks, like 2 by 4s, at the lowest (safe) point.
10-05-2020, 07:47 AM | #3 |
Moderator
Or you could take the front end off.
10-05-2020, 09:25 PM | #4 |
Who Changed This?
I didn't want to scare him off! It's easier at the factory, because the frame is less body.
Asshat (need a real name here, buddy!) did you remove the hood?
10-05-2020, 09:57 PM | #5 | |
BTW, my name is George.
10-06-2020, 10:14 AM | #6 |
Easiest way is to pull front end from firewall forward. I believe it is 12 bolts if you do it this way.
Regards Steve New Orleans |
10-06-2020, 10:50 AM | #7 |
Moderator
If you have ALMOST enough lift, just take the wheels off and set the truck on the ground.
10-06-2020, 11:09 AM | #8 |
Did you have the boom on the hoist extended all the way out? It will sometimes add more lift. As long as you don't exceed the weight limit.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
10-06-2020, 11:52 AM | #9 | |
Maybe I need a better hoist.
10-06-2020, 02:54 PM | #10 |
Who Changed This?
Pleased to meet you, George!
~Steven
10-06-2020, 03:31 PM | #11 |
You might be able to gain some extra height if the chain for your hook is bolted in as high up as you can get it to the hoist. I had to do that on my Dakota when the hoist was hitting the top of the garage door frame and the oil pan wasn't clearing the core support.
Also, try to use as short of a chain as possible (without damaging any critical components) to connect from the hook to the engine
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
10-21-2020, 03:55 PM | #12 |
So, I can remove the from section with pulling the fenders?
10-21-2020, 04:33 PM | #13 |
I'm wondering if I should go through the trouble of removing the front, so I don't have to go through the trouble of installing the tranny from the bottom. Then again, I'm not sure if my hoist will even clear the front body with the head on the motor. Another thing, I don't want to have to install the head on the block with the motor in the truck.
Only way to do this would be to buy a bigger engine hoist. Damn! Anyone know what the weight of the motor is with the tranny?
10-21-2020, 04:54 PM | #14 |
Motor and trans maybe 700 lbs.
10-21-2020, 05:05 PM | #15 |
OK - Thanks.
After looking at it, I think my hoist will get the motor over the body, even with the head installed. However, I don't know if I could get the motor AND tranny over the body, cuz I don't think the boom is long enough. Well, worst case, I'll just install the tranny the old-fashioned way.
10-21-2020, 05:07 PM | #16 |
Helped a guy once put a 235 in his 56 truck. Couldn’t lift it high enough due to low ceiling height in his little garage. Dropped the front down by bleeding all the air out of the tires.
Couldn’t roll it outside as there was 3 feet of snow by the door. We layed the motor and trans down flat on the floor on the drivers side. Picked it up flat like that. Cleared the sheet metal and barely missed the roof. Set it gently down in the engine bay On blocks. Adjusted the chains and uprighted it gently into position. Worked like a charm. Sometimes you gotta think outside the box! |
10-21-2020, 05:18 PM | #17 | |
Guess I'll just have to get it all assembled and hoist it up. No guts, no glory!
10-21-2020, 05:24 PM | #18 |
Be careful.
You get that much weight up high it wants to tip over. You got a pic of your hoist? |
10-21-2020, 07:14 PM | #19 |
I think it’s a 2-ton hoist.
10-21-2020, 07:41 PM | #20 |
Should be plenty big enough.
10-23-2020, 11:39 AM | #21 |
Moderator
I had a custom GMC panel once (see sig) and removed the engine for a re-cleanup. It was nerve racking. Just remember - 2 tons with the arm retracted, should have numbers on the tube for weights. Hey it's been done by many before so...
"You can do it Luke"
10-23-2020, 11:48 AM | #22 |
I personally like the idea of removing the front of the truck. If not the whole thing, at least the bumper, radiator and all that stuff. Then you have a clean path to where you need to be without having to deal with fender alignment after you are done. Just my .02. Gonna try that when my son decides and get's his motor all worked out.
10-23-2020, 11:52 AM | #23 | |
10-23-2020, 12:24 PM | #24 |
Moderator
It's up to you really. I just didnt want to fight it. And I could crawl in to do the wiring etc. since it's all custom. The only bolt on the front that just a little out of the way are the top fronts that attach the core support to the fender. But once you do them one time it's all good.
10-23-2020, 03:00 PM | #25 |
Not sure if its applicable here, but when I install an engine tranny combo in an MGB I raise the rear of the car on jack stands to help with the angle needed to clear everything.
