10-29-2020, 07:11 PM | #1 |
Reproduction Tach Dash Bezel Lens Text Not Lighting Up
I installed a CounterPart brand tach kit recently. I drove at night yesterday evening for the first time since I installed it, and I noticed that the speedometer and gas gauge text on the bezel lens are not illuminated like they were on the original lens. Is this a common problem with reproduction lenses?
10-29-2020, 08:20 PM | #2 |
The Older Generation
Re: Reproduction Tach Dash Bezel Lens Text Not Lighting Up
Looks like you have a couple of bulbs that aren't working for some reason. I would remove the bulbs and test them. LockDoc
10-29-2020, 08:34 PM | #3 | |
I just got done disassembling my gauge panel, and I have found that the green paint on the reproduction lens just isn't nearly as good as the original at conducting light through the lens. When I shine a flashlight on the back of the lens tin, the original lights up brightly, but the repro is dim. I'm wondering if there are multiple brands of repro lenses and if some are better than others. |
10-29-2020, 10:08 PM | #4 | |
LockDoc
10-29-2020, 10:09 PM | #5 |
10-29-2020, 11:01 PM | #6 |
10-29-2020, 11:38 PM | #7 |
I installed 168s, and it's definitely brighter, but the speedometer numbers and the fuel gauge text are still nowhere near as bright as with the original lens. I think I will start searching for a stock tach lens. That's not going to be easy...
10-30-2020, 12:51 AM | #8 |
Be careful handling the 52 year-old OEM lenses. The white markings and letters are highly water soluable. I was trying to clean up a junkyard lens with a damp paper towel, and the white stuff came right off. Just dust it with a camels hair brush or canned compressed air.
[Nice Orange Stepside, BTW.]
10-30-2020, 12:58 AM | #9 | |
10-30-2020, 10:12 AM | #10 |
I bought mine from GMCPauls, lights up just fine. Not sure of the manufacturer, but am very satisfied. Maybe you got a defective one.
10-30-2020, 10:38 AM | #11 |
Old member
Did you put the spacers in between the housing for the light to shine through. I have never had problems with aftermarket lenses. The cushions that go between the panels.
10-30-2020, 11:01 AM | #12 |
10-30-2020, 11:07 AM | #13 |
Are you referring to the spacers that look like black tootsie rolls and sit between the front bezel and the lens? I did reinstall those.
10-30-2020, 11:09 AM | #14 |
An additional note in the way of lightning, 2825 bulbs are the same as 194 and 168 and even brighter yet, if you're needing more illumination.
10-30-2020, 11:14 AM | #15 |
10-30-2020, 11:26 AM | #16 |
There are a bunch of little rectangular holes in the tin that clamps the lens into the bezel. I believe this is how the light from the bulbs gets to the lens. I took my gauge cluster apart last night and compared the effectiveness of shining light on these holes on my tach lens vs. the original lens. The original lens text lights up very nicely when I point a flashlight at those rectangular holes, but the tach lens does not. The holes in the tach tin look exactly the same as the holes in the original tin. It's gotta be the paint they used on the lens.
10-30-2020, 11:31 AM | #17 |
Could it be a problem with the tin being too close to the lens?
10-30-2020, 11:55 AM | #18 |
The original tin sits right up against the original lens, just like on the new setup. Here are some photos that show the rectangular holes that allow the light to get to the lens. I have the lens squeezed tightly against the tin, and I'm lighting it up with a flashlight. I will do the same with the tach lens after I take it apart again.
10-30-2020, 12:23 PM | #19 |
Here are the same photos, but of the tach lens and tin. The speedo doesn't have the same glowing halo around it that the original has. Also, most of the light is from sunlight shining in a window (where the numbers look white).
10-30-2020, 03:24 PM | #20 |
Old member
I just finished replacing the tach in my ramp truck. The other one burnt up. Brothers sent me another one. When I went to put it back in I noticed the lights where dim. The ground in the printed circuit board had a gash in it. I had to put a ground into the light socket and ground it to the tin. It's all back together now and everything works fine.
I use these LED lights https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 https://www.youtube.com/watch?v=fPrq2X1JHlI
10-30-2020, 04:09 PM | #21 | |
10-30-2020, 04:11 PM | #22 |
I saw an original tach lens at a place I visited a couple of months ago. I contacted the guy and he still had it, so I went and picked it up.
10-30-2020, 06:49 PM | #23 |
There’s an NOS lens on eBay right now but it’s pricey.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
10-30-2020, 06:52 PM | #24 |
10-30-2020, 06:53 PM | #25 |
Cool. I didn’t really check it out, I just saw it while browsing today. Glad you found one that works for you.
