Old 11-18-2020, 07:30 PM   #1
clemdaddy
clemdaddy's Avatar
centering brake pedal
I almost never do a tech thing and perhaps someone has already done this. But, a small thing that has always bothered me is that the auto and manual trans both use the same pedal hanger. When you change a manual to an auto and remove the clutch pedal (just like the factory did) then the brake pedal seems to be very close to the gas pedal. So, to fix this. I removed the clutch arm and cut the pedal off. Then cut the pedal off of the brake arm. Then the two pedals were sectioned and welded to the width of an early Impala power brake pad. The clutch and brake arms share a common hole which when bolted together to align them, I cut them off. The reason is to replace the brake arm with the clutch arm because the clutch arm kicks off to the left, therefore moving the pedal to the left.
If you want to move the brake pedal to the left and have a wider power brake pad, this is one way to do it. I hope some of this makes sense, if not perhaps the pics will.
clemdaddy is offline   Reply With Quote
Old 11-18-2020, 08:50 PM   #2
AcampoDave
AcampoDave's Avatar
Re: centering brake pedal
Nice, I like that a lot. Too bad my welding skills could prove that mod to be lethal.
AcampoDave is offline   Reply With Quote
Old 11-19-2020, 12:02 AM   #3
cgrocen
Nice work. Can you show us a photo of the setup in the truck and how it looks next to the gas pedal?
cgrocen is offline   Reply With Quote
Old 11-19-2020, 09:49 AM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Oh man, that' looks great clemdaddy.
Old 11-19-2020, 09:55 PM   #5
Bomp
Bomp's Avatar
Nice work Pop's.
Now I know where I got my mad welding skills.
Bomp is offline   Reply With Quote
Old 11-19-2020, 10:25 PM   #6
MusicMan70
MusicMan70's Avatar
Great Job!!
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 11-19-2020, 11:03 PM   #7
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
Very Nice.. what Year Impala Brake Pedal is that?? 60's ?? Thanks
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 11-20-2020, 12:39 PM   #8
pdxhall
pdxhall's Avatar
That's a great idea. A little too late for me but I would have stolen it at the time.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 11-21-2020, 07:18 PM   #9
64shortbox
64shortbox's Avatar
Good Job! I feel the same way you do and moved my brake pedal over when I converted my 64 drums to a 73 Disc brake setup. Since I went to Discs I used a 73 pedal though.
64shortbox is offline   Reply With Quote
Old 11-21-2020, 09:34 PM   #10
Justin71105
Actually started modifying mine today and didnt think about using the clutch pedal to offset it a little to the left like it needs to be.
Now know what I will be doing tomorrow ��.
1964 C10 Resto-mod
5.3L - L59
Justin71105 is offline   Reply With Quote
