Old 11-22-2020, 07:46 PM   #1
chevykevy
chevykevy's Avatar
64 super track bar needed ECE
I am preparing to lower a 64 c10. I lowered a 64 a few years ago and learned that it is a year specific trac bar mount on the frame. I called Early Classic Enterprises at the time and they made a bar specific for the year. Anyone know if others may make the bar, or someone may have one? Thanks
chevykevy is offline   Reply With Quote
Old 11-23-2020, 08:51 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 64 super track bar needed ECE
No Limit (a vendor here), POL and CPP makes them.
Old 11-23-2020, 04:00 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
What was the reason to get a “special” track bar made?
Is the frame mount different?
I would use the long version that has a Trailing arm mount on the passenger side.
And not use the rear axle mount at all.
Keith
Convert to disc brakes.
Old 11-23-2020, 05:16 PM   #4
cwcarpenter98
cwcarpenter98's Avatar
The 63 and 64 panhard bar mount on the axle was a welded on stand similar to the 60-62 frames. The bar was pretty much parallel with the axle and it was longer than the 65-72 panhard bars. The mounting point on the frame for 63-64 has a different angle than the one for 65-72. I ran into that with my 63 that has a 65-70 axle in it
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 11-23-2020, 06:58 PM   #5
chevykevy
chevykevy's Avatar
Thanks all.
cwcarpenter; thanks for the explanation
Old 11-23-2020, 07:36 PM   #6
lolife99
lolife99's Avatar
Porterbuilt sells mounts for both ends of the track bar at
www.pbfab.com
https://pbfab.com/1963-72-fully-adjustable-trac-bar-kit
Keith
Old 11-23-2020, 09:00 PM   #7
chevykevy
chevykevy's Avatar
Thanks lolife
Old 11-23-2020, 09:34 PM   #8
chevykevy
chevykevy's Avatar
Thanks lolife
