![]() Join Date: Jul 2009
Where to find switch for hazard flashers?
My wife and I had a breakdown in a bad spot on the interstate at night with no hazard flashers. Best I could do was leave a turn signal blinking. Needless to say, she doesn't want to do another roadtrip until that is fixed.
I'm assuming the problem is the switch. This is the one on the right side of the column down near the dash. I believe it is supposed to stay out when you pull it, but mine doesn't. Any case, I'm not having much luck finding one. Anybody know who sells one? This is for my 78 GMC K15. Thanks!
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ![]() 2001 GMC Sierra K2500 |
![]() ![]() Join Date: Jul 2002
Re: Where to find switch for hazard flashers?
The button just screws in. Many get broken off over time. You get get replacement buttons at most auto parts places, well at least you use to. I think the switch is part of the turn signal cam/switch assembly. The button that stick out is not normally part of the kit from what I remember, that has to be bought seperately or reuse old one.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 11-27-2020 at 04:15 PM. |
Thanks Bill! I've still got the button on there, and I did put in a new turn signal switch assembly when I rebuilt the column. I just don't recall ever noticing (or more likely just forgot) that it also provided the hazard light switch. Maybe something is just misaligned, but likely that switch was bad on the reproduction part from day 1.
Am I right that the button is supposed to stay out when you pull it to engage the flashers? I'm not looking forward to pulling the column back apart...
That is what mine does There is not a separate switch from what I remember, it is just a spot for it to screw in on the turn signal cam/switch thingie. Mine has the outer collar you pull to pull the actual switch out. I think the earlier models just had a simple button you pulled out. Not sure if the button or the switch makes it stay out.
The switch does the hold out part. You can put the later version collar/button on the earlier switches. At least I was able to on my 75.
Don't forget that the hazard flasher is a separate unit from the turn flasher. Possible your problem is a bad hazard flasher. |
![]() Join Date: Oct 2014
You push the hazard button IN to activate the flashers and pull the outer ring out to release the flashers.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
#7 | |
On our old Jeep, which has a GM steering column, the button was broke off so I found a screw with the right threads, and made up a 'handle" with a couple washers and a nut turned tight up against the head. Works just fine. I traded off the Suburban about six months ago, but I could go out and look at the 76 GMC tomorrow in the daylight. The battery will be long since dead, however.
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
Do ya suppose its just the hazard flasher gone bad?
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
#9 | ||
Installed a flasher module and now the hazards come on. Its just that the button automatically pops back out after about 2 seconds. It's never easy... Thanks for the help and suggestions!
