Old 11-29-2020, 05:50 PM   #1
Carolina68
Exclamation 73-87 c10 long bed on a c30 crew cab???
I actually have a 90 square body c3500 or c30, Whatever you want to call it. It was a 3+3 truck but it’s has been converted to a flat bed. I am wanting to remove the flatbed and put on a regular long bed once again. Will a 73-87 c10 long bed fit on the c30 crew cabs with single axle? Thanks you in advance. I have searched and searched but haven’t found a good answer. Thanks you.
Carolina68 is offline   Reply With Quote
Old 11-30-2020, 09:01 AM   #2
Re: 73-87 c10 long bed on a c30 crew cab???
It probably should. I have not seen many crewcabs with a extra long wheelbase that would make an 8 foot longbed not fit.
Palf70Step is online now   Reply With Quote
Old 11-30-2020, 12:57 PM   #3
SCOTI
SCOTI's Avatar
If it's a stock chassis, the LWB bed will fit. If it's a modified C&C set-up, then the frame could be longer depending on what the truck was originally intended to do.
Easiest way to tell is to measure the wheel base & confirm it matches that of a CC LWB truck (single wheel or dually).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-01-2020, 09:08 AM   #4
sweetk30
sweetk30's Avatar
Crew cab long bed with box is 164.5 center to center of axles .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 12-01-2020, 02:42 PM   #5
TKCR
TKCR's Avatar
I know there’s one around me, I see it once in a while driving around. My lord, that thing is LONG! First and only one I have see, in person that is.
Old 12-01-2020, 04:24 PM   #6
Yeah they are L O N G. I got the pleasure of maneuvering one thru some narrow streets in villages in Okinawa. Holly mackerel it was rough.
Old 12-02-2020, 08:37 PM   #7
v30crewcab
v30crewcab's Avatar
It will fit..
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
73-87, c10, c30, crew cab, flatbed
