12-05-2020, 10:35 AM | #1 |
headliner trim hitting visor ?
I have a 80 truck that had no headliner and have all the parts from a 84 ish truck. I,m mounting all the trim and drilling the holes but it looks like the fr. pillar trim will hit the visor mounting bracket. Do I have to trim the pillar trim or does the visor sit over top once the headliner is in place or do I have it in the wrong position. A picture would be nice if you have one
12-05-2020, 01:17 PM | #2 |
Re: headliner trim hitting visor ?
The visor mounting base should sit just past the trim piece & not make contact. The visor holes are possibly not in the correct spot or the trim is slightly off in alignment.
12-05-2020, 10:09 PM | #3 |
Ok thanks I will see how the cross bar lines up again and see if I have wiggle room for the visor
12-06-2020, 12:01 AM | #4 |
On my 83 the visor base sits on the headliner, factory headliner.
12-06-2020, 09:33 AM | #5 |
Mine did that on the passenger side, made a notch in it with a round file.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
