Old 12-21-2020, 01:32 PM   #1
Speedracer39
Speedracer39's Avatar
Trailing arm option
I am wondering those that have replaced the factory trailing arms did you use a newer style with johnny joint ends and what are your opinions on using them?
Speedracer39 is offline   Reply With Quote
Old 12-21-2020, 01:43 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Trailing arm option
I highly recommend these from Tinworks Fabrication.
Excellent Quality and customer service.
https://tinworksfabrication.com/prod...y-truck/63-72/
Keith
Convert to disc brakes.
Old 12-21-2020, 03:54 PM   #3
SeanB242
SeanB242's Avatar
Second this. Put them on sons truck. Really nice.
SeanB242 is offline   Reply With Quote
Old 12-21-2020, 04:40 PM   #4
Speedracer39
Old 12-21-2020, 04:42 PM   #5
Speedracer39
Originally Posted by Speedracer39 View Post
Is there a advantage of having a Johnny joint over a stock bushing?
Old 12-21-2020, 10:35 PM   #6
lolife99
lolife99's Avatar
There’s not much if any articulation in the stock bushing.
The I-beam design of the stock trailing arm allowed it to twist.
When you build a solid trailing arm (round or square tube) it has to have a flexible joint at the front.
Keith
Old 12-22-2020, 10:16 AM   #7
Speedracer39
Old 12-22-2020, 10:17 AM   #8
Speedracer39
Thanks for the explanation.
Old 12-23-2020, 11:10 AM   #9
SCOTI
SCOTI's Avatar
Well..... It doesn't have to. There have been multiple options out there w/poly bushings. But those options built using square/round tubing w/poly bushings will definitely bind before the stock stuff would.
I think of it as going from Radials to Bias-Ply tires (backwards in functionality).
The combo of the original I-beam construction, length, orientation, & the front rubber bushings made them compliant enough to survive. Start changing some of those dynamics & it will possibly impact the effectiveness on the others.
If you're choosing aftermarket tubular constructed Truck-Arms, they need to have a spherical joint to work better than what came form GM.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-23-2020, 05:47 PM   #10
lolife99
lolife99's Avatar
Thanks for the CORRECT explanation.
Keith
