Utility bed fitment?
There’s a Reading utility bed for sale near me, and I’m considering buying it for my ‘66 C20 long bed for use in my handyman business. Anyone have experience or knowledge to pass on if this will fit without crazy modifications?
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: Utility bed fitment?
My 66 with a utility box did not have these:
. . They are the bed mounting brackets. .I'm not sure if they'd be in the way for mounting a utility box.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
Lots of these trucks were bought with utility bodies, it can't be rocket science to mount them. I don't know if the details varied from one manufacturer to another, but I have a Stahl body on mine and can take pics if it helps you. I have removed some of the bolts etc in preparation for lifting the body off, but there's still enough to give you the idea. But again maybe Readings were built differently.
![]() ![]() ![]() Join Date: Jan 2018
If the utility bed has the wheel opening in the same location, it will probably be fairly easy to get it attached. You might have to make some brackets for it, but if you have a welder, that probably won't be too hard to do
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
I’ve decided to go with a small cargo trailer instead. Thanks for your input, though.
When I was a framing contractor I loved my service box. A place for everything and everything in its place.
Moderator
![]() ![]() Join Date: Aug 2011
Knapheide makes a nice service box that fits our trucks. https://www.knapheide.com/uncategori...-service-body/
#8 | |
I do as well. Maybe one day I'll have a c20 or c30 with a utility bed as my tow pig/ old car rescue rig
Back when mine was on the road. Now being restored.
